PopcornFX freeze effect
Posted By hcameron90 Last Week
hcameron90
hcameron90
Posted Last Week
Posts: 233, Visits: 1.5K
Hey Guys
I have the popcornFX learning package and it has a popcorn mesh template.
I want to use this particle  but instead of using the popcornFx with the mesh flying everywhere,
is there a way to freeze the effect at a certain point to use as a prop/particle?
Thanks
mtakerkart
mtakerkart
Posted Last Week
Distinguished Member (8.3K reputation)Distinguished Member (8.3K reputation)Distinguished Member (8.3K reputation)Distinguished Member (8.3K reputation)Distinguished Member (8.3K reputation)Distinguished Member (8.3K reputation)Distinguished Member (8.3K reputation)Distinguished Member (8.3K reputation)Distinguished Member (8.3K reputation)
Last Active: 3 hours ago
Posts: 2.4K, Visits: 18.5K
I'm not english language friendly so I don't understand your request...
Can you be more specific on which particle do you use ?
Do you want to freeze the velocity of the particles and they stay in the air ?
hcameron90
hcameron90
Posted Last Week
My Bad I should have used different terminology.
Instead of using freezing I should have said static.
So when you press Shift+S to simulate the effect
So I was using the mesh effect using popcorn as the mesh.  is there a way ( once I press shift + S)  to create a static or still effect
to the mesh emitter. So instead of it moving, it's still.
Does that make sense?
mtakerkart
mtakerkart
Posted Last Week
the shift+S is only to run your particle in looping mode without hit the play button of your scene , it's just a sort of an endless running preview to see
the different behavior by changing the settings.
You can make sort of freeze/stop after hiting the play button then stop .
