hcameron90
hcameron90
Visits: 2.0K
Hey Guys I have the popcornFX learning package and it has a popcorn mesh template. I want to use this particle but instead of using the popcornFx with the mesh flying everywhere, is there a way to freeze the effect at a certain point to use as a prop/particle? Thanks
mtakerkart
mtakerkart
Posts: 3.1K,
Visits: 28.2K
I'm not english language friendly so I don't understand your request... Can you be more specific on which particle do you use ? Do you want to freeze the velocity of the particles and they stay in the air ?
hcameron90
hcameron90
Visits: 2.0K
My Bad I should have used different terminology. Instead of using freezing I should have said static. So when you press Shift+S to simulate the effect
So I was using the mesh effect using popcorn as the mesh. is there a way ( once I press shift + S) to create a static or still effect to the mesh emitter. So instead of it moving, it's still.
Does that make sense?
mtakerkart
mtakerkart
Posts: 3.1K,
Visits: 28.2K
the shift+S is only to run your particle in looping mode without hit the play button of your scene , it's just a sort of an endless running preview to see the different behavior by changing the settings. You can make sort of freeze/stop after hiting the play button then stop .
