bdpbiz777 (12/16/2019)
You can try the Curve Editor Plugin for free, but from what I've seen, the trial is only for 24 hours. Before the Reallusion moderators start bumping gums, I came to the conclusion that the trial plugin only works for 24 hours because 24 hours ago I decided to try the plugin which is now GREYING OUT THE CONVERT CURVE DATA.24 Hours ago I could convert curve data with the trial, which by the way, I was going to purchase, but I wanted to make sure that the Curve Editor worked as advertised being that there are so many cheesy, unprofessional issues with iClone. Another nickel and dime tactic courtesy of Reallusion?The trial version can be used for 15 days. The full version works as advertised so you have no worries there.
Please can I also remind you that a basic requirement of participating on the forum is that you are polite and respectful at all times. I have already had to remove a couple of your posts because of infringements of the forum rules, and you have had another fail with this post which is only your third. We welcome constructive criticism but please don't use every post as an excuse to throw insults around. This is considered trolling and is against forum rules.
