Problem with transforming Genesis 2 character including full body suit
Posted By 3dtester 6 Years Ago
Problem with transforming Genesis 2 character including full body suit...
3dtester
3dtester
Distinguished Member (4.7K reputation)Distinguished Member (4.7K reputation)Distinguished Member (4.7K reputation)Distinguished Member (4.7K reputation)Distinguished Member (4.7K reputation)Distinguished Member (4.7K reputation)Distinguished Member (4.7K reputation)Distinguished Member (4.7K reputation)Distinguished Member (4.7K reputation)
Posts: 995, Visits: 2.2K
It's been a while since i last used CC3 to import a character. I was occupied with learning iClone.
But now i wanted to import one of my DAZ characters including an astronaut / space explorer outfit.
Unfortunately it does not work.
https://forum.reallusion.com/uploads/images/3fbd293d-68bd-4056-b129-e069.jpg
I don't know what the problem is. I can transform the same character with different clothings without problems.
https://forum.reallusion.com/uploads/images/3b6ee46d-8ded-4eaf-88a3-2801.jpg
Any help would be highly appreciated.
6 Years Ago by 3dtester
3dtester
3dtester
Update: i was able to import the character into 3DX withouth the morphs.
With the morphs added, 3DX crashes on loading the file.
So it must have something to do with the morphs.
However, i still get the "no compatible profile" message in CC3 without the morphs.
I would need to manually add all the morphs to iClone then. But that's not what i wanted.
Sigh Sad
Last Active: 4 hours ago
Posts: 8.1K, Visits: 60.5K
likely what you running into is the DAZ suit hiding underlying body. That means an incomplete body gets exported as FBX, and will not be recognized by CC3P.
See this tut for a fix:
Posts: 9.1K, Visits: 21.8K
3dtester
3dtester
Ok, thanks Rampa. That's the case pretty sure then...
So do you think there is any reasonable way to import it through CC3 at all?
Or should i go the iClone way?
Did you look at my tutorial?  You can get anything into CC3 that way.
If you tell me *exactly* what it is I will test it myself (give me the exact name of the outfit).
3dtester
3dtester
Sorry KT, i've been slower than your reply Smile
Thanks, i'm currently trying it with the suit unparented...
Remember you may need to delete the original figure (just used to pose the suit properly) and then reload it again (so you can export both to CC3).
Again, any troubles just let me know what and I'm sure I can get it in CC3 for you (to let you know how).
3dtester
3dtester
Yeah, it works.
But then i have the standard character face inside the helmet.
Wouldn't it be better to load back-in my own character instead?
You don't have to load in the standard character -- you can load back in whatever character you want.
Or you can just save the outfit in CC3 and apply it to ANY of your characters (which is what I do).  It's up to you.
