The cheapest way to speed up iRay renders.
Posted By jarretttowe Last Week
jarretttowe
jarretttowe
Posted Last Week
Posts: 431, Visits: 2.2K
As new people come to the forum, I think this bears repeating. There is a way to speed up your renders considerably, and do it cheaply.
1. Render at half size as lossless png files.
2. Buy Gigapixel AI for 99$.
3. Double size the renders in the Gigapixel batch function.
I have used this program extensively, and for animations, it is great. Of course resolution is not identical to a native render, but it comes in at a 1/4 of the render time.
Also, I have found that simply doubling my model textures works extremely well, too.
3d guy1
3d guy1
Posted 2 Weeks Ago
Veteran Member (597 reputation)Veteran Member (597 reputation)Veteran Member (597 reputation)Veteran Member (597 reputation)Veteran Member (597 reputation)Veteran Member (597 reputation)Veteran Member (597 reputation)Veteran Member (597 reputation)Veteran Member (597 reputation)
Last Active: 3 days ago
Posts: 169, Visits: 1.4K
Hi,
Im confused.  How does this do video?
Posted 2 Weeks Ago
Distinguished Member (13.3K reputation)Distinguished Member (13.3K reputation)Distinguished Member (13.3K reputation)Distinguished Member (13.3K reputation)Distinguished Member (13.3K reputation)Distinguished Member (13.3K reputation)Distinguished Member (13.3K reputation)Distinguished Member (13.3K reputation)Distinguished Member (13.3K reputation)
Last Active: 52 minutes ago
Posts: 7.0K, Visits: 21.5K
A lot of people render to a sequence of PNG files, and then use a video editing application (NLE = Non-linear editor) to make a video from the PNG files.  That gives you a lot of control over many aspects, including more "video conversion/compression" options.
So you'd render a "half-size" set of PNG files, and use that magical tool up-size them to full resolution, and then put the full-sized images into your NLE.
Desktop (homebuilt) - Windows 7, i7-3770k CPU, GTX 1080 GPU (8GB), 16GB RAM, Asus P8Z77-V Pro motherboard, 500 GB SSD, terabytes of disk space, dual  monitors.
Posted 2 Weeks Ago
Posts: 10.6K, Visits: 18.2K
I'm reading that processing an image may take quite some time so it will be interesting to compare rendering at a higher resolution with rendering at a lower resolution and use Gigapixel AI.
The approach is interesting though. I have tried other applications that claim the same thing, and I have never been impressed.
jarretttowe
jarretttowe
Posted 2 Weeks Ago
Free demo. Easy to test!
Posted Last Week
jarretttowe (12/7/2018)
I did download the demo, and I am impressed by the quality. It is also quite fast, so it would beat rendering at a large size. Thanks for the tip!
illusionLAB
illusionLAB
Posted Last Week
Last Active: 29 minutes ago
Posts: 321, Visits: 3.6K
If the ultimate goal is to do 'low sample' Iray renders and then upscale with this plugin to get HD video it's worth pointing out that any sort of "smart" process... like Ai Denoising, approaches every frame as new frame - that is, it's unaware of what it did to achieve the 'denoise' or 'upscale' for the previous frame.  When you process a frame sequence with a series of smart filters you also usually create an entirely new fault which only becomes apparent when played as a video.  Smart filters like "NeatVideo" (best denoiser!) have a comprehensive "temporal" section to make the plugin aware of the previous and next frame to minimize the variance you get from processing single frames.  The first 'video' render I did with Blender's cycles and it's denoiser looked great, but had a 'fixed pattern' noise that made the render look like you're watching it through a screen door.  Fortunately, they do have a setting to 'randomize' the noise pattern (side effect of the denoiser... go figure!) making it look more like film grain or video noise... which is less annoying than fixed pattern and also something that NeatVideo can deal with quite well.
Posted Last Week
I have NeatVideo also, so I will see how that works in comparison. Thanks for pointing that out.
Posted 9 days ago
I found that PNG images in Gigapixel are saved as 48-bit PNG, which makes them huge. I did not find a way to save as 24-bit (8-bit per color). I can convert afterwards, but it is an extra step.
Posted 9 days ago
illusionLAB (12/8/2018)
...approaches every frame as new frame - that is, it's unaware of what it did to achieve the 'denoise' or 'upscale' for the previous frame.  When you process a frame sequence with a series of smart filters you also usually create an entirely new fault which only becomes apparent when played as a video.
I have shared the same observation here a few times over the past few months.
Several people have assumed they'd be able to render with fewer Iray "iterations" when they make a video.  I strongly disagree, for the reason described in the quote above.  Noise and grain that might not be distracting in a still image will catch your eye when it changes (flickers) from frame-to-frame.  That became clear to me way back when the Indigo plug-in became available.
So if you are doing 60-second renders in CC3, you might want to prepare for 90-second renders (per frame) in iClone.
