animagic (12/3/2018)Check for Hub-related downloads here: C:\Users\<username>\AppData\Local\Reallusion\RLDownloads, with <username> the name of your Windows login name.
I did not find the install files, so next time I'll do like you and download the installer without the Hub.
I did not reinstall character creator 3, as I think I figured out the problem.
I was wrong about this issue starting 2 days ago, it was probably always there. The problem is that there is simply something wrong with the CC Embed Morphs "cc3_female_01_Head.ccSlider" and "cc3_male_01_Head.ccSlider". In the UI they are located
at "Actor/Head/Full Head/CC3_Base Female" and "Actor/Head/Full Head/CC3_Base Male". So this would be something to fix on your side. Those 2 morphs mess up the left ear. I can post this in the technical issues as a bug, if you could confirm that those sliders mess up the left ear on your computer too (check the faces at the top of the left ear).
note: The reason why I mistakenly thought it started 2 days ago is because I opened my Blender project from 2 days ago, and saw that the OBJ was ok, but it was because I used the "mirror topology" option, and I edited the right leg, but that fixed the left ear because of mirroring!
