lvanvalk
lvanvalk
Visits: 139
How do I make the clothing fit loosely instead of clinging to the body? One of my characters is old and heavy and it looks pretty bad having the cloth clinging to big, old, boobs.
Last Active: 53 minutes ago
Posts: 9.1K,
Visits: 21.7K
You don't say what program you are using, but let's for a moment say it's iClone and perhaps CC3 for putting/creating the clothing. Inside the conform panel of any particular clothing item there is an "Increase size" adjustment, as well as a "Conform clothing" checktab you can use to achieve this look, although you'll need to experiment with it some. Physics can also help, depending on the clothing, but you'll have to be a lot more specific on what you are trying.
lvanvalk
lvanvalk
Visits: 139
I have tried making the changes in both IC7 and CC3, and it is still having issues. I have increased the size and the loose fitting will only go up to a 5. Are there any other changes that may work? Thank you so very much for your quick reply and help.
duchess110
duchess110
Posts: 2.0K,
Visits: 15.5K
Hi Ivanvalk Have you tried inside CC3 doing edit mesh and using the pull option try and pull away the cloth where it cling to much. I do not know if you have any 3d modelling software but there is Autodesk Max or Maya where you could adjust the fit. Another cheaper piece of software is 3d coat where you could take the character and clothing into the tweak room and try pulling the cloth from the body.
Duchess Designs Store
lvanvalk
lvanvalk
Visits: 139
Thank you everyone for your suggestions, I put a dark hoodie on her and that seems to hide the issue pretty well.
lvanvalk
lvanvalk
Visits: 139
Yes, I did try pulling the mesh down but I wasn't getting the right result. This is my first foray into 3D and a very big novice, but I am learning to enjoy. I do not have any other 3D software, once I gain more experience I may get more in-depth and venture into other software. Thank you everyone for your help. Little by little with everyone's help I am slowly learning. The wonderful tutorials made my final decision to try iClone over Poser.
