Dessiex
Dessiex
Visits: 130
Sorry if this has been posted a gazillion times before... I use Crazytalk Animator so I don't really have any use for iClone except for converting motions to use with Crazytalk's G2 characters. Am I able to run 3dXchange Pipeline as a standalone application and convert motions? Or do I need to have iClone also (even though I don't plan on using it?) Thanks for your help!
Last Active: 14 minutes ago
3DXchange 7 Pipeline standalone will allow you to convert BVH motion files into rlMotion files that can be used in CrazyTalk Animator 3. However because BVH files are not all the same in structure, I would advise downloading the trial version of 3DXchange 7 Pipeline so you can try the process and see if it works for the motion files you have first. https://www.reallusion.com/iClone/pipeline.html
