Import Character to UE4 with MorphTargets. With and without Maya in between.
Posted By spaehling 6 Years Ago
Import Character to UE4 with MorphTargets. With and without Maya in...
spaehling
spaehling
Veteran Member (783 reputation)Veteran Member (783 reputation)Veteran Member (783 reputation)Veteran Member (783 reputation)Veteran Member (783 reputation)Veteran Member (783 reputation)Veteran Member (783 reputation)Veteran Member (783 reputation)Veteran Member (783 reputation)
Posts: 16, Visits: 242
FIXED: Check my 3th Post or just search for Solution on this site.
Hey Guys,
since i started with Iclone7 and CC i have this issue with MorphTargets. I want to import my finished Character + Animations into UE4 from IClone after i'm done with Animation.
No it gets a bit complex, but there 4 possible.
What i do:
1. Import from CC3 directly into UE4
2. Import from CC3 with import and export from Maya in between, into UE4.
3. Import from IClone7 directly into UE4
4. Import from IClone7, with import and export from Maya in between, into UE4.
End Result:
1. Everything is allright. All Morphs inside.
2. No Morphs anymore (only 1 left)
3. Everythign is allright expect of wrong root bone name. (Delete unused morph, works fine)
4. No Morphs anymore. (only 1 left)
https://forum.reallusion.com/uploads/images/02b4777a-13cb-4a00-ab76-25e8.png
https://forum.reallusion.com/uploads/images/aa3a7e47-0d7e-484b-8356-4ec8.png
After importing into Maya, i can see all Blendshapes working fine. Doesn't matter if from Iclone or from CC3
https://forum.reallusion.com/uploads/images/cd730d89-2063-4c08-872c-a43d.png
Import and Export Settings Maya and Unreal:
Export Settings Maya: Bake Animation Off, FBX Version (i tried 2015, 2016/2017, 2018) UP Axis (Z. Also tried Y, just in case)
https://forum.reallusion.com/uploads/images/77b69377-cc02-475a-aaf3-252a.png
if you guys have any idea, i'm happy for any ideas. My next step is going through the plugin tool of maya. but i run out of ideas Smile
greetz Phil
6 Years Ago by spaehling
vidi
vidi
Distinguished Member (31.5K reputation)Distinguished Member (31.5K reputation)Distinguished Member (31.5K reputation)Distinguished Member (31.5K reputation)Distinguished Member (31.5K reputation)Distinguished Member (31.5K reputation)Distinguished Member (31.5K reputation)Distinguished Member (31.5K reputation)Distinguished Member (31.5K reputation)
Posts: 10.8K, Visits: 40.2K
Maybe "on " helps ,
 I use Unity but  for import all Blendshape it is need a Animation where all Morphs are one Keyframe on the timeline
When I import my FBX with this animation Unity regonized this all a Blendshape  and listed it in the inspector
I think Unreal works in the simliar way ?
liebe Grüße vidi
spaehling
spaehling
vidi (11/20/2018)
Maybe "on " helps ,
hey,
thanks for your answer. I tried this before, but i tried it again. Sadly it doesn't work. Also tried with and without resample all.
i tried a few different setups. but feel free to answer. i try it again and again until it works Smile
spaehling
spaehling
Reallusion Team found a Solution. It's simple and effective.
Solution:
Just rename _ncl1_7 and _ncl1_8 to something else. I tried test_1 and test_2 and it worked!!!!.
The main problem is the first _ from _ncl1_. If you just rename it to "ncl1_" it works Smile
That also allow's me to fix this problem: https://forum.reallusion.com/394209/IClone7-Unreal-Export-Root-Bone-Name
Now i can also rename the Root-Bone to simple "root" and import it into ue4. FINALLY Smile
https://forum.reallusion.com/uploads/images/2391fc5f-e79b-4d35-ab34-5bd2.png
spaehling
spaehling
the story goes on Smile
https://www.reallusion.com/FeedBackTracker/Issue/UE4-import-Morph-Targets-doesnt-work-cause-Blend-Shape-Names-are-to-long
It got fixed.
Note: if you reimport your character with morph targets in ue4, you need to reopen the skeletal mesh window, to see the morph targets.
4 Years Ago by spaehling
