hustydj
hustydj
Visits: 94
Hi~I made the eyebrow by using polygon,not using texture. So after I used Transformer to import fbx file which was exported from Daz into CC3,I found that the eyebrow couldn't morph following the facial expression. I changed the attributes of the eyebrow mesh to Hair、cloth、accessories and so on,but nothing worked. So is there any way to make eyebrow mesh to morph following facial expression?
Posts: 9.1K,
No, there is not. The facial expressions are morphs off the base avatar. So textures mapped will conform, but external cloth (like you have found) will not. Cloth for beards will "move" according to the jaw bone, but cloth mustaches will also not follow the visemes of the lips. Again, this is just how it works, and there is nothing you can do to fix it.
hustydj
hustydj
Visits: 94
Thank you for replying~ So I use 【 iClone_Daz_Genesis_Extension】to export my character fbx file,then import into Iclone7 by 3DXchange. I should also adjust the facial bone to make the eyebrow mesh follow the facial expression. It cost just a few minutes and works well~ But what a pity! iCone7 cant use Iray render plugin yet~
eternityblue
eternityblue
Visits: 2.7K
Reallusion seriously needs to address this, it is one thing for most character's eyebrows, but decent mustaches and beards are impossible right now. I was hoping they would address in CC3 but I guess it will be some time. Pity, real humans are hairy.
My system: i7 3770 Gtx1060 6GB
Last Active: 11 hours ago
Thank you for the feedback. We still need to do more testing but we will look to improve the handling of beards, moustaches and eyebrows in a future upgrade.
