Thanks for all your feedbacks
For my specific problem (because there's sadly never one solution for each transition problem) I may have found a workaround !
I add motion 1, add a transform key at the end
I add motion 2, add a transition key at the beginning
I add the desired transition from motion 1 to 2 and select "create transition clip" (just discovered this), right clicking on motion 2.
I "reset pivot" on this transition clip and then I tweak this transition with some transform key where needed.
The end steps allow me to keep the transition in place, removing this slide effect, I just have to add transform keys if the avatar must move during this transition.
sonic7 (11/12/2018)
Neal >>> " ... you have to add a dummy prop, select character, link to the dummy, select dummy, Turn dummy to correct orientation, select character and play animation to see if it was correct, ... " <<<
Yes .... I've been playing around with that approach myself - with, unfortunately, limited results.
I never figured how to make this working. And I didn't understand why it could be better to link a dummy prop instead of just turning the avatar directly. I'll try again.
sonic7 (11/12/2018)
@ DrNemesis ... I didn't realize Align Motion was broken ... well that explains why the results have been so 'hit and miss'. I'll add my vote right now ..... thanks. Oh ! As a beginner I didn't know it was broken, I thought it was normal behaviour. I can not wait to see what it looks like when not broken.
6 Years Ago by
Walvince
