gicag14102
gicag14102
Visits: 2.1K
Gloves Boots I hope someone could challenge to fix it properly.Other suit and hair came properly after some fix with colition.
4 Years Ago by
gicag14102
gicag14102
gicag14102
Visits: 2.1K
Hey Mike, I finally figured out, you don't need to buy that for it, if you don't like. I exported as obj from daz then import as accessories, then hide mesh and setup as boot. This tricks works when transformer twisted mesh.
chris_466129
chris_466129
Visits: 100
Thought I would add this here for anyone having trouble bringing in a waist to thigh gun holster from Daz to CC3. It's actually really simple, but had me hung up for a couple of hours fighting it as an accessory trying to convert to clothing in CC3 with transferring weights, which doesn't work for this kind of item. Here's the solution: Bring in a Daz Gen 8 character with only the holster attached and nothing else. On import, set the layer to a high number (like 4 or 5). Click the item in the scene, add to custom as pants. Load your character that you want to attach the holster to. Add the "pants" which is really the holster. Adds and moves perfectly.
shadybearbklyn
shadybearbklyn
Visits: 2.7K
Hey Mike. I’m having an issue with the Guillamane hair. I can import it into CC3, but it’s over one million polys. When I try to reduce the polygons it gets stuck at 43% every time.
Posts: 9.1K,
Is that misspelled? I can't find any hair named that on the Daz site (a direct link there would be helpful).
shadybearbklyn
shadybearbklyn
Visits: 2.7K
Posts: 9.1K,
Ah, okay -- no need for me to even look at it, then. It's fibermesh hair, and you should never try and use it in CC3/iClone. It just will never look right -- as you've discovered, it has WAY too many polygons when translated but even if you did remove 3/4 of them it wouldn't look good. Stick, always, with polygonal hair (and if you ever have any wonder -- because sometimes it won't say -- just ask me and I'll tell you in advance so you don't waste your money).
shadybearbklyn
shadybearbklyn
Visits: 2.7K
Thanks Mike. I’ve had a hard time looking for a hairstyle with a heavily receded hairline. Any suggestions?
Posts: 9.1K,
I have a video tutorial on making the Classic Taper into a balding hairstyle. I also have tutorials on making your own hair and making receding hairlines is pretty easy with that (I would highly recommend at least trying to make your own hair, as it's very liberating). Making sparse hair yourself is pretty easy -- it's more luxurious hair that takes some real talent.
shadybearbklyn
shadybearbklyn
Visits: 2.7K
Thanks Mike. I remember checking those out a while ago. It might be time to dive in.
