What type of character are you using? G1, G2, or G3?
Typically you can select the existing character and then double click the new character and it will replace only the character leaving the animations intact.
Depending upon the type of character how you would change the colors of the character.
If it is a G1 character then you would have to do a sprite replacement.
For a G2 character that is render style compatible (RS), you can change the colors of the various render style groups from the Composer or use my EZColor system (available in the Marketplace) [shameless plug].
If it is not an RS G2 character then, if you have CTA pipeline, you can make it RS compatible by assigning the various sprites to the various render style groups.
If it is a G3 character then you use a photo editor to change the colors.
Jeff
