Make Character appeare over time
Posted By videodv 6 Years Ago
videodv
videodv
Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)
Posts: 342, Visits: 12.0K
Just wondering if its possible to make a character appeare over time and not just turn the visability on and off.
Cheers
Chris.
Peter Blood
Peter Blood
Distinguished Member (12.5K reputation)Distinguished Member (12.5K reputation)Distinguished Member (12.5K reputation)Distinguished Member (12.5K reputation)Distinguished Member (12.5K reputation)Distinguished Member (12.5K reputation)Distinguished Member (12.5K reputation)Distinguished Member (12.5K reputation)Distinguished Member (12.5K reputation)
Posts: 2.3K, Visits: 9.4K
Hi: Smile
You can do that with the opacity slider.
On frame #1, set all of the avatars components to "0" on the opacity slider.
Skip ahead on the time line to where you want him to appear completely
and reset all of the components to 100%. The distance between the two settings
determines how fast the avatar will appear. Short distance = quickly Long distance=slow.
Hope this helps.
Cool pete
https://forum.reallusion.com/uploads/images/d9f2ee62-c67b-4c8e-b3cf-4e36.png
http://www.youtube.com/user/peterblood50?feature=mhee
jlittle
jlittle
Posts: 1.9K, Visits: 17.1K
There is always the Opacity setting that can be used to fade in and out with.
Jeff
EDIT: Ah, cross post with Peter.
6 Years Ago by jlittle
Posts: 8.2K, Visits: 26.5K
A couple quick ideas:
1) Keyframe the OPACITY channel STRENGTH.  However, with multiple materials involved, that might be laborious, though you might be able to multi-select the materials.
2) Do it in your favorite NLE (video editor).  Render the scene with and without the character, and blend (dissolve) the two clips in the video editor and the character will "appear" over time.
ADDED:  Wow, a lot of simultaneous responses being typed.
6 Years Ago by justaviking
Kevin.S
Kevin.S
Distinguished Member (10.4K reputation)Distinguished Member (10.4K reputation)Distinguished Member (10.4K reputation)Distinguished Member (10.4K reputation)Distinguished Member (10.4K reputation)Distinguished Member (10.4K reputation)Distinguished Member (10.4K reputation)Distinguished Member (10.4K reputation)Distinguished Member (10.4K reputation)
Posts: 1.2K, Visits: 71.8K
here is a quick sample
Freelance Artist Kevin.S
https://forum.reallusion.com/uploads/images/57cedd8e-58c4-42ce-b2f4-9646.png https://forum.reallusion.com/uploads/images/5a59e070-66a0-4914-b0a5-b2dc.png
Email: animatemyart@gmail.com - Web Site:  www.animatemyart.com
6 Years Ago by Kevin.S
Clark
Clark
Veteran Member (834 reputation)Veteran Member (834 reputation)Veteran Member (834 reputation)Veteran Member (834 reputation)Veteran Member (834 reputation)Veteran Member (834 reputation)Veteran Member (834 reputation)Veteran Member (834 reputation)Veteran Member (834 reputation)
Last Active: 4 hours ago
Posts: 70, Visits: 7.3K
I have done this by selecting the character and changing the opacity of all associated items (selected all at once).  There have been times when I wanted to manipulate the opacity that I would need to work with attached items individually.
Late again
6 Years Ago by Clark
videodv
videodv
Thanks Guys most helpful.
Cheers
Chris.
videodv
videodv
Here is a very quick and dirty test
Hopefully you will be able to see it.
So thanks once again guys
Chris.
Edited to remove video.
Edited to re-add video.
6 Years Ago by videodv
Oops... Your video cannot be viewed.  It is probably marked as "Private."
