videodv
videodv
Visits: 12.0K
Just wondering if its possible to make a character appeare over time and not just turn the visability on and off.
Cheers Chris.
Peter Blood
Peter Blood
Posts: 2.3K,
Visits: 9.4K
jlittle
jlittle
Posts: 1.9K,
Visits: 17.1K
There is always the Opacity setting that can be used to fade in and out with. Jeff EDIT: Ah, cross post with Peter.
6 Years Ago by
jlittle
Last Active: 3 Weeks Ago
A couple quick ideas: 1) Keyframe the OPACITY channel STRENGTH. However, with multiple materials involved, that might be laborious, though you might be able to multi-select the materials. 2) Do it in your favorite NLE (video editor). Render the scene with and without the character, and blend (dissolve) the two clips in the video editor and the character will "appear" over time.
ADDED: Wow, a lot of simultaneous responses being typed.
6 Years Ago by
Kevin.S
Kevin.S
Posts: 1.2K,
Visits: 71.8K
Last Active: 50 minutes ago
Visits: 7.3K
I have done this by selecting the character and changing the opacity of all associated items (selected all at once). There have been times when I wanted to manipulate the opacity that I would need to work with attached items individually. Late again
6 Years Ago by
Clark
videodv
videodv
Visits: 12.0K
Thanks Guys most helpful.
Cheers Chris.
videodv
videodv
Visits: 12.0K
Here is a very quick and dirty test Hopefully you will be able to see it. So thanks once again guys Chris. Edited to remove video. Edited to re-add video.
6 Years Ago by
videodv
Oops... Your video cannot be viewed. It is probably marked as "Private."
