Kelleytoons (11/13/2018)
Tony,
I think you're wrong about USB -- while the manual instructions are crazy stupid, you CAN connect via USB without a hotspot (I did it at least a couple of times). It seems to imply you need to use a hotspot, but after I tried it once with it I just never did it and it worked fine. Now, I've never had a trouble with wi-fi in my house (where I do this) so I stopped doing it that way but if you'd like I can go over it again to show you (again, I have done it without the hotspot enabled -- but I didn't see any improvements)..KT - I think you still had a Wifi connection, just coincidentally physically while your phone was connected to the PC, and your phone was charging.
In other words, just by mere fact that there is the USB wire plugged from the phone to the PC didn't auto-generate or initialize some connection. It was still WiFi.
Think - there would be no need to enter an IP address if it was a USB hardware connection, but it still asks you to set up one. In other words, in the IP port area in the Face Live iClone settings, it does not then switch to, say, something like "USB Connection", or "wired". You are still going through WiFi.
But how about this. Because I can already imagine you saying, "Well, I had it working..."
So, I am interested, with what you say, if you could accomplish this:
Try turning off WiFi while your phone is plugged in, and tell me how you get it to work, (because I did try that)
(1) turn off phone cellular
(2) turn off phone WiFi
(3) plug in phone to PC
In this case the phone does, yes, generate an address with less #'s, but this address is never detected as working in the iClone settings when you type it in.
And so, I thought "maybe you need a port #?"... But, what port # would you use for a true USB hardwire connection.
Likewise, in the In the iPhone app itself, it does not say, 'wired USB connection", or something to that effect, which would indicate that strict hardware connection...
Better yet, point to an RL document that details how to specifically use a hardwire non-wireless connection. Because, I do not see any documents posted by RL that directly point to a hardwire USB connection. They only speak of a wireless USB connection (which is not what I was referring to.)
They are using "USB" to mean a 'non-WiFi' wireless connection. It actually is another way of saying HotSpot tethering.
I am not saying it is your responsibility to educate me or correct me, but if you have a technical list of steps, then please tell us, because then you are aware of something that is not listed in the RL documentation (setting up a non-wireless/non-WiFi signal/non-USB tethered hotspot signal, which is **strictly** hardware USB connected only.)
