What you are experiencing is not normal (shouldn't be, I think). In the Iray hardware settings, you can disable use of the GPUs. See if that makes a difference.
However, I just started up Character Creator 3 and I noticed that GPU usage goes to 100% when the application is in focus, even without engaging Iray. So I wonder if that's what you are seeing.
EDIT: You can use a tool like GPU-Z to monitor the usage of your cards. CC uses only one card, so your other card should be "free".
6 Years Ago by
