magiccak
magiccak
Visits: 132
I have applied some, but I can't really say. The bumps are really small or there aren't any.. Thanks
Last Active: 3 Weeks Ago
a) How did you make them? b) Try to make a grotesquely obvious "bump" and see if that shows up c) Can you share some pictures?
magiccak
magiccak
Visits: 132
I'm not very good with Character Creator. I was hoping my question, and your reply, would help inspire someone else to come and provide a useful answer for you.
For "stubble" I assume it would just be a 2D thing you'd actually "paint" on the skin, like pores and pimples and wrinkles, but I haven't personally done it so I have to good advice or tips, only guesses.
A longer beard, I assume, would done like hair. Hair is done with "ribbons" that are painted with hair textures and a very important application of "opacity" (transparency) to make it look like strands of hair rather than flat ribbons.
Sorry I can't be much more help. Someone else, please?
Last Active: 11 minutes ago
Posts: 15.7K,
Visits: 30.5K
Normal maps are an optical illusion. What you want to use instead is an Displacement map, which will actually move the mesh up or down. It is often used in conjunction with a normal map, because the mesh itself may not be able to represent intricate details.
Last Active: 12 hours ago
Sorry if I don't remember (it's a bit early and I just got back from the gym) but are you the guy who's trying to 3D print something? If so then, no, a bump map is only a visual "trick" to fool the eye into thinking there is depth. It won't print or adjust the mesh in any way. To deform the mesh physically you will have to apply a morph of some sort. I'm not sure but there may be morphs folks have made to do this but I kind of doubt it. For one thing there really isn't any real advantage to doing this in the work we normally do with these programs. Whether you are designing games, animating in iClone, or even making gloriously detailed stills, you actually want to stay away from detailing in the mesh. Doing it with maps (the illusion of such details) is always MUCH better in terms of computer processing. My guess is that if you really need this stuff you will have to do it yourself -- so you'll need to learn modeling, which isn't easy but it can be very fun. Search the web and see what you can find.
magiccak
magiccak
Visits: 132
@animagic Thank you my man, I have just used my Normal Map as a "Displacement", moved the "strength slider" a bit down and it's done. Nearly exactly how I wanted it to be. Perfect. Thanks a lot! @Kelleytoons Yes, I'm the guy This software really is amazing, I just need to orientate myself in it. Still, thanks for tips, but I don't gravitate to modeling due to it's complexity. I've actually tried ZBrush, but I didn't really enjoy it... You actually reminded me that I should go to the gym too and not only sit and play with this new "toy" of mine Thank you both guys & have a nice day!
danielswright2311_182877
Visits: 454
Normal maps are a effect to look like there are bumps on the face, it does not add any extra real detail to the mesh. We use to call them bump maps till direct x got all tech on us all.
Check out my new Bible Forums
