Alolu
Last Active: 8 hours ago
Visits: 6.3K
This is a Genesis3 transformed in CC3. The poses are converted from DAZ with a little tweaking. Hard spotlight and a softer IBL (100). Just getting the hang of it. I can't wait for the iClone plugin later on!!!
Very artistic. I especially like the first two (no disrespect to the third one). I'm having trouble thinking of the correct word, but I love the way she's... savoring? soaking in? embracing?... the light in the first (top) image. Thanks for sharing
6 Years Ago by
Rogue Anime
Rogue Anime
Visits: 3.4K
TOP SHELF! ~V~
Val RogueAnanda
Alolu
Visits: 6.3K
Thank you @justaviking! Let's just say the third is her opposite reaction to the light. Dance interpretation perhaps?
@Rogue Anime Thank you!!!
6 Years Ago by
Alolu
sonic7
sonic7
Posts: 1.7K,
Visits: 19.4K
Nice images .... yes iRay's *look* is appealing. The 'unknowns' about the iClone version (for me) are: ● Will consecutive frames 'blend' together nicely once the anination is played (without any visual flicker) - in other words - will some sort of 'blending filter' be required? ● Will the lighting 'exposure levels' remain reasonably consistant during camera moves where the lighting 'influence' changes. If these don't turn out to be a problem then the extended render times will certainly be worth it to get this *look* ....
6 Years Ago by
sonic7
Peter Blood
Peter Blood
Posts: 2.3K,
Visits: 9.4K
Your shots look really nice. Very artistic in their simplicity. pete
http://www.youtube.com/user/peterblood50?feature=mhee
Alolu
Visits: 6.3K
@sonic7 Thank you!! I'm sure RL will make the iClone version extraordinary. And yes, the render times will probably be very time consuming. @Peter Blood Thank you!!
dead legends
dead legends
Last Active: 6 Years Ago
Visits: 40
Wow these are really beautiful.
Postfrosch
Postfrosch
Posts: 6.9K,
Visits: 18.4K
Hi Guys, you are waiting for a special version of the iRay plug-in for IC 7.3xxx. ? I have to disappoint you here (probably). There will (probably) be no special IRay plug-in for IClone. It's the same as CC 3. So it will have the same features and components as well. RL repeatedly writes that the plugin is used for both CC3 and IClone 7.3xxx. It just does not work in 7.3 because the access from Iclne 7.3 to the plugin is not yet implemented. This will happen only with the Icloen version 7.31 or 7.32. But the IRay PlugIn itself will not change anything. I was able to do without CC 3 on the plug-in and will probably do it also IClone 7.3xxx
Greets from Germany Postfrosch
3dtester
3dtester
Visits: 2.2K
Postfrosch (10/13/2018) I was able to do without CC 3 on the plug-in and will probably do it also IClone 7.3xxx Do you mean you were able to live without the iray plugin in CC and iClone, or do you mean you were able to use the iray plugin without either CC or iClone? Just confused...
