Last Active: 54 minutes ago
New Features Added in Character Creator v3.01:Transformer:- Added: Optimize the texture import process of Transformer, including auto texture mapping, material settings, texture reversing, etc.
*If the texture mapping incorrect, you can use the .ini method to correct it.
- Enhance the Transforming results on Michael 4 and Victoria 4 characters by popping up a selection window for correct UV mapping.
Bugs Fixed in Character Creator v3.01:Transformer- Fixed: Eye bones displaced when transforming G2 avatar (FT#5171, 5181)
- Fixed: Specular texture is not correctly converted to roughness texture
Not fixed yet, but targeted to be fixed in this patch: - Fixed: Transformer crashes if any roughness maps on any of the eye parts in the ini file (FT#5210)
Export: - Fixed: CC3 Export to Unity3D Fails with error "Fbx export failed." (FT#5207)
- Fixed: CC3 Export FBX & Export to Sketchfab - posed only in a T-pose (FT#5188)
Embed Content- Fixed: CC3 Male Inverted Alpha (FT#5172)
6 Years Ago by
Dan Miller
Dan Miller
Last Active: 9 days ago
Visits: 1.8K
What is an .ini method? The manual doesn't mention anything about an .ini method.
Your search for ".ini method" returned 0 result(s).
Is there a fix for the outdated cc1 morphs issue? I get the prompt to update every time I open CC3. Starting to get pretty annoying. Thanks.
6 Years Ago by
danmiller
Warped Reality VFX
Warped Reality VFX
Visits: 8.1K
Hello, danmiller the ini file method is a texture profile located in cc3 template DazResource folder you can create your own profiles that take care of missing textures or any texture setup you want. I hope this helps.
Warped Reality VFX.
RobertoColombo
RobertoColombo
Posts: 1.6K,
Visits: 3.0K
Hello Peter, Thanks for the news. Any possibility to have in next patch a push-button export of generated low-poly characters in .iAvatar format and/or directly to iClone ? Regards Roberto
Dan Miller
Dan Miller
Visits: 1.8K
Hi Kevin, it does help. Now I know where they are located:
\Template\Character Creator 3 Template\DazResource\TextureProfile
Is there a reference for how to apply them? A Google search shows .ini coming up a lot but nothing in the documentation that I see. Now I get the concept that they are texture profiles but I wouldn't know what to do with it. When I open one up it has a slew of settings several pages long, so I'm not sure how I would just intuitively know what to do with it. I'm seeing a bunch of time wading through various videos to try and figure it out. Seems odd it wouldn't be in the documentation.
I appreciate you taking the time to show me where they are at. I was watching a video awhile back and there was a mention of an .ini file and I had no idea even where it was so thanks.
If you want to generate your own ini file (this assumes you are using Daz characters and Transformer):
6 Years Ago by
Dan Miller
Dan Miller
Visits: 1.8K
Thanks Mike, I have it bookmarked now. I appreciate the link to the video.
eternityblue
eternityblue
Visits: 2.7K
I'm happy to hear the G2 bug is getting fixed
My system: i7 3770 Gtx1060 6GB
RobertoColombo (10/9/2018) Hello Peter, Thanks for the news. Any possibility to have in next patch a push-button export of generated low-poly characters in .iAvatar format and/or directly to iClone ? Regards Roberto
Hi Roberto... We are working on adding an easy option to send low poly CC characters back to iClone. We hope to have more news soon.
RobertoColombo
RobertoColombo
Posts: 1.6K,
Visits: 3.0K
Peter (RL) (10/10/2018)
Great news Peter, Thanks
