Issues Creating Morphs and Saving Characters with CC3
Posted By StrangeMotions90 6 Years Ago
Rated 4 stars based on 1 vote.
StrangeMotions90
StrangeMotions90
Veteran Member (516 reputation)Veteran Member (516 reputation)Veteran Member (516 reputation)Veteran Member (516 reputation)Veteran Member (516 reputation)Veteran Member (516 reputation)Veteran Member (516 reputation)Veteran Member (516 reputation)Veteran Member (516 reputation)
Posts: 24, Visits: 153
Since the launch of Character Creator 3, I have run into many issues. Currently, my main issue I'm having is not being able to save Characters / Avatars with their clothing & Hair also none of the Morphs I made work properly even though I followed RL's step by step tutorial. If anyone knows what I may be doing wrong or just knows how to fix this then can you please help me out with this. ThanksReallusion's Tutorial:https://www.youtube.com/watch?v=AAT0m...
CC3
Last Active: 4 hours ago
Posts: 9.1K, Visits: 21.8K
Tell me which character(s) you're having trouble with specifically.
StrangeMotions90
StrangeMotions90
All of my Daz characters I export over to CC3. I can save their morph sliders but they end up disfiguring my characters and then I am unable to save my character to custom folder with all of their clothes, hair etc.
You will need to bake your morphs before you bring them over (for the avatars -- you can bring over clothing morphs).
StrangeMotions90
StrangeMotions90
How do you mean? I'm not sure I understand. Bake the morphs in Daz itself? How do you do that, do you know?
Yes, in Daz.  In your FBX export options look at "Edit Morph Export Rules".  It should have an entry called "Final Anything Bake", and nothing else (unless you know what you are doing).
If you still have problems give us some screen shots of your entire process (a video would be better, but a separate screen shot for each and every window will work).
StrangeMotions90
StrangeMotions90
So I now understand what you meant by baking in Daz but I'm still having the same problem, maybe I'm still missing a step so I've just recorded my step by step setup of how I export etc. to CC3. The only thing I think I didn't record was added the CC3 T-Pose as the character was already saved with it in Daz. Thank you for taking a deeper look into this for me.
Sorry -- do NOT take out that "Head Ignore" on the morphs screen.  And don't embed textures.
I need to eat but those are the two things that jump out at me.  I'll look at the rest afterwards.  But you might want to try it again with those two settings.  And this might help as well:
Also -- the morphs you are trying on that character -- are they just standard for CC3, or did you create them yourself (if the latter I suspect I know what you did wrong.  If the former -- that's very odd).
6 Years Ago by Kelleytoons
Okay, just took a VERY brief (I really need to eat) glance and I think I know where you went wrong in your morphs.
You need to morph from the base character you started the morphs with.  So if you want to use a morph from a Gen 3 character, first you import a base Gen 3 character, save as an avatar, and use THIS morph as your starting morph for your other morphs.  That way it's just the difference between the two.  If your morph is another character, same thing -- start with a completely default Gen figure that matches the morphs.  Otherwise you'll get into big problems.
StrangeMotions90
StrangeMotions90
Ok, you should really go and eat and do whatever you have to do, I can always wait until later when you are free to help. I'll try this again with the changes you have told me about and record it so you can have a look later, I'll also have another look at your video. I did check it out last night but to be honest, Blender has always overwhelmed me. Although I have been using iClone and Daz for nearly 3 years now I would very much still consider myself a newbie so I'll try my best to use your tutorial. Thanks again
