Cary B
Cary B
Visits: 3.8K
I have read a post about the frame rate for imaging sequences being off, and I have gathered that there are a number of other bugs in the 7.3 release. But I'm not sure what they are, outside of some installation problems with the hub. I understand the imaging sequence bug is a big for for a number of users, even a killer. But what other bugs have been found? Or is everyone so busy with CC3 that the new Iclone version hasn't been given much of a test drive yet? The tutorial I saw on the new paths look great ...at last a chance to actually move the camera whn you are laying down a path. That's something I've been wishing for a long time.
AniMajik
AniMajik
Visits: 395
iClone 7.3 Bug: Look At Camera does not work for some models (it works for CC characters) I have not tested all yet. This is a deal-killer for me as I use this feature a lot.
-AniMajik
TopOneTone
TopOneTone
Visits: 3.2K
I am experiencing constant crashing with IC7.3 and the Project recovery is not working. I am also experiencing long waits for projects to load and there is a lag in implementing many of the functions. Given I have not had any problems at all with IC7.2 and my PC is well within spec, I think there are some issues that need to be addressed...hopefully very quickly. Anyone else experiencing similar problems? Cheers, Tony
dante1st
dante1st
Visits: 2.3K
This may be minor, but whenever I send a character from CC3 to iClone, if iClone is not ALREADY open, all it does is open, and the character doesn't go over there. I then have to click the button in CC3 to send the character a second time, before they show up in iClone. Don't know which program is at fault for this, but this wasn't an issue before.
My iClone short films: https://www.youtube.com/iClone316
Last Active: 8 hours ago
Yes, I noticed this right away. It's a bit annoying.
Rogue Anime
Rogue Anime
Visits: 3.4K
Hello friends - I am experiencing significant issues with the content manager in iClone 7.3 it suddenly does not 'see' A LOT of the content inside some folders - Looking within Windows I can SEE IT THERE - I can drag it into the scene, but I can no longer access or see the content in many folders that I KNOW IS THERE. This is new, and REALLY annoying. Take look here ~V~
Val RogueAnanda
kungphu
kungphu
Visits: 7.1K
Crap!!! I just downloaded CC3 and iclone 7 on my new machine. I have a new project starting this Friday. I know better... but I’m so tempted to try IC7.3 on this project. Maybe I try my normal workflow through a few scenes and see if I run into any show stoppers? I’ve already experienced the issue with transferring from CC3 to IC7. Annoying but not a deal breaker.
My "NEWEST" Latest Movie Made With Amaaaazing iClone
Alien Maniac
Alien Maniac
Visits: 2.1K
I have finally got the CC3 installed with IC 7.3. yea. OK I went CC3 and tried to use it. Noting works correctly and all menu items are greyed out. I try to load a character from withing it and no nothing happens after 20min. SO, I closed it. I opened IC and loaded a cc2 model and went to edit it in CC3. CC3 opens and nope not there. Same problems. So why did get this CC3 for again? Perhaps just a bad install due to the 2 hour download (??whaaat) from the server demand at the time? What should I do? Uninstall and reinstall? Wait for a year to get the bugs out? Yes I watched the intro videos and thats no help t all right now. ANY Suggestions? All my Nvidia cuda settings are good and it is running as admin too. Thanks for any ideas. repeat scroll 0% 0%; display: none; opacity: 1;"> | no-repeat scroll 100% 0px;"> | repeat scroll 0% 0%;"> | no-repeat scroll 100% 0px;"> | repeat scroll 0% 0%;"> | repeat scroll 0% 0%;"> | repeat scroll 0% 0%;"> | repeat scroll 0% 0%;"> | repeat scroll 0% 0%;"> |
repeat scroll 0% 0%;">Text-to-speech function is limited to 200 characters repeat scroll 0% 0%;"> repeat scroll 0% 0%;">
MSI GE66 Raider, Intel 10th Gen, I7, SC Turbo to 5.3 GHZ, 240HZ, 64GB 3300 Ram, 2x 1TB M2 SSD Drives, NVIDIA GPU RTX 2070/8GB, 55" Sony 4K Monitor External data drives total 7 TB. and an AUDIO Studio Recording system.
kungphu
kungphu
Visits: 7.1K
Rogue Anime (10/3/2018) Hello friends - I am experiencing significant issues with the content manager in iClone 7.3 it suddenly does not 'see' A LOT of the content inside some folders - Looking within Windows I can SEE IT THERE - I can drag it into the scene, but I can no longer access or see the content in many folders that I KNOW IS THERE. This is new, and REALLY annoying. Take look here ~V~
I’m experiencing the same thing. A ton of my animations are missing. Just one folder from a pack and within that pack there are only a handful of animations. There should a be a bunch instead.
bexley
bexley
Visits: 370
The oulines for the TOON shader are now too thick for any kind of hi-res (1K plus) work. Unless you like that "drawn with a crayon" look. :-( --Bex.
