Sunrise765
Sunrise765
Last Active: 3 Weeks Ago
Visits: 288
. I did a blood splat at the end of the clip show in the first picture, but when I played it back it was also there from frame 1 on. I only want it in the end frames How can I get that to happen? Thanks in advance for any help.
gordryd
gordryd
Last Active: 10 hours ago
Visits: 7.5K
You should be able to use "Visibility". Go to frame 1, select your item, and click the 'closed eye' icon in the Modify panel (I'm not at my iClone computer now, so can't send a screen shot). On the timeline, scroll to the point where you want the item to appear and click the 'open eye' in the Modify panel. Voila! Hope this helps...
Peter Blood
Peter Blood
Posts: 2.3K,
Visits: 9.4K
You can go to the opacity slider for the prop in the modify panel. Slide it to zero, then go to the frame that you want it to appear in and slide the slider to 100%. That will fade it in to that point, so go to the frame just before you want it to appear and slide the slider back to 0%. It will be invisible until the frame you want it to show. pete
http://www.youtube.com/user/peterblood50?feature=mhee
Sunrise765
Sunrise765
Visits: 288
Thank you for your suggestion, I will try that.
Sunrise765
Sunrise765
Visits: 288
Thank you for your help, I will try it.
