jimbobsquarepants
jimbobsquarepants
Last Active: 6 Years Ago
Visits: 79
Hi all. I've been setting up a scene in iclone 7 which consists of a model road made in sketchup, and a model truck, also made in sketchup. I want the truck to follow the contours of the road as it moves along it. However, I notice that when I select the road prop the selection lines are outlined as a box shape on the road prop. Thus, when setting a path and snapping to terrain it simply follows a long flat line above the curves in the road. Is this problem able to be resolved? If I apply self mesh to the road prop will that allow the truck to follow the shape? Any help would be great. Thanks
raxel_67
raxel_67
Group: Banned Members
Visits: 2.0K
If the Road is set as terrain, select it, and on the modify tab uncheck use bounding mesh (Or something like that) and try laying Down the path again, hope this helps
