Peter (RL) (8/27/2018)
Do make sure you have correctly copied the appropriate "Reallusion" folder to Daz Studio.
So for example copy the Reallusion folder from iClone_Daz_Genesis_Extension_v4_IC7\DAZ Genesis Extension\Daz Genesis to iClone\Genesis8_Female to the location below (default install).
C:\Users\Public\Documents\My DAZ 3D Library\data\DAZ 3D\Genesis 8\Female\Morphs
Then make sure you restart Daz Studio for the changes to take effect. Now once you apply the Genesis8_Female_iCloneFaceKey.duf file to your character it should be correctly assigned. Then do the same for the Male character and Genesis 3 characters if required. Instructions are also supplied in the iClone_Daz_Genesis_Extension_v4_IC7.zip file.
Peter,
While on the subject of importing/exporting G8F - could you help in clarifying the export motion clip from iclone 7 - via 3dx pipeline - to Daz as BVH.
I have read a thread on Daz forums that says it is doable but have not been able to replicate without distortions on import of the BVH to Daz.
It used to be a problem with G3F but that is fixed with the latest release of iclone 7. It has something to do with the Daz A pose in G8F conversion to Tpose in iclone and then the reverse. Any help or direction much appreciated. I have been messing with this for days to no avail.
