The UN Task force weapons pack has guns which have a script that can animate firing the gun with both sound and visual fx. My question is, is it possible to edit the scripts to customize them with different sounds or visuals? There is a right-click menu item to export a lua script pack, but trying to activate it, I get the following message, "The script has failed due to protection settings."
So why is there an option to export the lua script if it is blocked?
I know you can export a persona as a lua script, and I use that often to group animations into special collections. But this is a lua script embedded in a prop which I'm trying to access.
Any ideas?
