Posts: 5.0K,
Visits: 15.9K
@justaviking No problem Yes it is definitely has to be fixed/improved as Peter vouched for RL to look into it: https://forum.reallusion.com/FindPost335058.aspxI forgot to mention, that I used super-sampling 3x3 in all tests. For DSR it sure could be turned Off. It would make it render even faster without quality loss. @dogged2003 DSR hack/trick is for those, who use 2K monitors with Nvidia GPUs (I believe for people who use 4K monitors it comes natural) and render at 1080p. https://forum.reallusion.com/FindPost334935.aspxNeed to check all those boxes (or at least 4.00x), then switch display resolution to 3840x2160px. Hit Ctrl+7 in iClone and render (make sure to turn super-sampling OFF). If you have Glare enabled in Visual, make sure to turn it Off as well, or set to minimum as it would be blown out of proportion. @Data Juggler Hit Ctrl+F to bring some of iClone statistics on-screen (top-left in viewport)
6 Years Ago by
Posts: 5.0K,
Visits: 15.9K
Double....
6 Years Ago by
Data Juggler
Data Juggler
Posts: 1.7K,
Visits: 5.4K
Thanks.
Data Juggler
Data Juggler
Posts: 1.7K,
Visits: 5.4K
I finally got a chance to try this, and after I turned on DSR 4.0 x, changed my resolution to Dynamic 4096 (or whatever), and I couldn't read anything on my screen. I was able to hunt around with Windows Magnifier and put everything back, but that makes my pc not useable with a font that small. Just changing my project render settings to 3840 x 2160 and turning Super Sampling off increased my render speed to about 2 seconds per frame, which I can tolerate. I will probably still buy a new GPU, but until then I can live with this speed.
Posts: 5.0K,
Visits: 15.9K
Yes, I forgot to mention you need a good magnifying glass to view the screen . Whenever I use it, the reason being is not to speedup the render (the difference in speed between full screen in 2k and 4k with DSR is neglect-able), but rather to illuminate GI flickering and jagged edges on some glowing objects, which is specific to certain projects.
Data Juggler
Data Juggler
Posts: 1.7K,
Visits: 5.4K
I am having a flickering issue now with hair when I turned of super sampling. I am trying with Super Sampling back on, just goes back to being really slow. I will buy a new GPU before I judge too much on speed. I am getting a little over 2 frames per second with super sampling 3 x 3 turned on, so still better than before with 1920 resolution it was 5 seconds. To me writing more pixels would take longer, but I guess the scaling down takes time.
Last Active: 4 hours ago
Visits: 60.6K
SS takes longer because it is writing each frame multiple times and combining them. If you turn it off, you will be essentially the same speed as rendering in preview mode, even with the other high quality boxes checked. You might test rendering at 4K and resampling to 1080 in a video editor. See how long that takes.
6 Years Ago by
Data Juggler
Data Juggler
Posts: 1.7K,
Visits: 5.4K
I still get the flickering, so Super Sampling didn't help. I was working on my other issue of diagonal lines, which I solved by increasing the self illumination of the walls. I had switched out the Image Based Lighting image: And I think I had modified the Ambient Occlusion just clicking buttons and seeing what happens, and this caused the little lines to appear. I don't remember how to get back the default Global Illumination Indirect Light image, I looked in the templates folder, but seeing it and knowing which one is the right are two different things. At least I know Super Sampling is not the culprit.
6 Years Ago by
Data Juggler
Data Juggler
Data Juggler
Posts: 1.7K,
Visits: 5.4K
One thing I noticed from watching my video again, is that I am moving my camera and zooming in, it seems to flicker more the further it is zoomed out. Once the camera is close up the flickering stops. I read another post about Depth of Field being the culprit, is there a way to turn that off so I can see if that is the cause. Should I switch back to my original post? (these two issues are semi related I think). Thanks
Data Juggler
Data Juggler
Posts: 1.7K,
Visits: 5.4K
I found the setting for Depth of Field, and it is not Activated, so I guess that isn't it. I will try using it so the background is not focused on.
