eternityblue
eternityblue
Visits: 2.7K
I'm getting a totally black IBL after baking, is this some issue with my video card or is there something I'm doing wrong? I have a 1060 GTX.
My system: i7 3770 Gtx1060 6GB
TheOldBuffer
TheOldBuffer
Visits: 6.4K
It.s a known bug and listed in the issues thread. It's been known about for months and for something so important it's long overdue being fixed but I guess the dev team are all working on CC3 and iClone updates. Everytime they add new features, something we need gets broken.
Homebuilt computer - Windoze 10, INTEL i9 9900 k @ 5.1 GHz, EVGA RTX 2080 TI XC ULTRA, 16GB 3100 MHz RAM, Asus Maximus Hero XI motherboard, Sound blaster Z series. iClone6 & 7 Pipeline, Crazytalk 8, Crazytalk Animator 2, Facefilter, Pop video 3, Hitfilm 4Pro, Cubase 8.5 Pro,
Last Active: 3 minutes ago
eternityblue (7/20/2018) I'm getting a totally black IBL after baking, is this some issue with my video card or is there something I'm doing wrong? I have a 1060 GTX.Are you able to render a 360 panorama image? If this doesn't work also, please can you send us your project so we can take a look at it. Please send a download link (Dropbox, Google Drive, OneDrive etc.) to Technical Support referencing this thread and the team will investigate further. Thanks.
eternityblue
eternityblue
Visits: 2.7K
How do I render a 360 degree image without the bake working? And it is any project, this is a universal issue for me.
raxel_67
raxel_67
Group: Banned Members
Visits: 2.0K
Peter means 360 image export, it is in the render tab. I have this issue as well, with all projects, it is not related to the driver it is an issue with the latest version, as the lack of drag and drop some users are reporting or also in my case i don't have undo unless i run iclone as admin, all thanks to the last update
Last Active: 11 hours ago
Posts: 5.0K,
Visits: 15.9K
raxel_67 (8/7/2018) ... also in my case i don't have undo unless i run iclone as admin, all thanks to the last updateBoom! Thank you Raxel! One issue was bugging me lately, is that with latest Indigo plugin (v4.12) iClone was crashing, or come up with errors when I hit Indigo render button. I had to export the scene first and then render it separately. I was blaming Indigo since its previous versions are still working fine. But apparently creating a new shortcut to iClone with "Run as.." checked solved the problem.
raxel_67
raxel_67
Visits: 2.0K
Good to know my problems solved a problem my theory is this: There is something weird with the 7.22 update installation either the installer is screwing up privileges (undo requires iclone to run a subprocess known as undo/redo manager) and without said privileges subprocesses don't run properly or the issue lies with how rl hub installs patches. I need to uninstall and reinstall iclone but this time i will install the patch manually. By the way none of this issues occur with 7.2, everything goes to the toilet after updating edit this issues happened since 7.21
6 Years Ago by
raxel_67
eternityblue
eternityblue
Visits: 2.7K
raxel_67 (8/7/2018) Peter means 360 image export, it is in the render tab.Ah, thanks! So, is there any special instructions for using this, or do you just put the camera where you would have put the dummy when baking IBL? As is it is already an improvement.
Posts: 15.7K,
Visits: 30.5K
eternityblue (8/7/2018)
raxel_67 (8/7/2018) Peter means 360 image export, it is in the render tab.Ah, thanks! So, is there any special instructions for using this, or do you just put the camera where you would have put the dummy when baking IBL? As is it is already an improvement. Indeed, just put the camera where the dummy would have been. Also, make sure the image size is Ultra HD (it defaults to that).
Posts: 5.0K,
Visits: 15.9K
raxel_67 (8/7/2018)
Good to know my problems solved a problem my theory is this: There is something weird with the 7.22 update installation either the installer is screwing up privileges (undo requires iclone to run a subprocess known as undo/redo manager) and without said privileges subprocesses don't run properly or the issue lies with how rl hub installs patches. I need to uninstall and reinstall iclone but this time i will install the patch manually. By the way none of this issues occur with 7.2, everything goes to the toilet after updating edit this issues happened since 7.21 OK, just don't forget to post an outcome
