Sign_guy52
Sign_guy52
Visits: 120
Hello.. Each time I try to render a scene, iClone renders only the first 900 frames regardless of where I set the stops. Any Suggestions?
Last Active: 54 minutes ago
How many frames are in your project? If there are 1800, there are really only 900 single frames (iClone renders 1/2 of all the "frames" of any scene). To get more, you'll need to increase the number of frames in your project (I hope this makes sense -- I'm a bit loopy on drugs right now).
6 Years Ago by
Last Active: 11 hours ago
Sign_guy52 (7/11/2018) Hello.. Each time I try to render a scene, iClone renders only the first 900 frames regardless of where I set the stops. Any Suggestions?
Hi... Open Project Settings by pressing CTRL+SHIFT+P. Then change the "Total Frames" to the number you require up to 54,000 frames (15 minutes). Once you have done this do remember to drag the end maker under the Play Bar to the far right hand end.
