sonic7
sonic7
Posts: 1.7K,
Visits: 19.4K
raxel_67
raxel_67
Group: Banned Members
Visits: 2.0K
That looks like flares you could create using the hdr feature in the visual tab
sonic7
sonic7
Posts: 1.7K,
Visits: 19.4K
Can't remember if I tried that Raxel.... I'll give it a try .... thanks
6 Years Ago by
sonic7
illusionLAB
illusionLAB
Visits: 4.8K
Fusion...
sonic7
sonic7
Posts: 1.7K,
Visits: 19.4K
Hi Mark ..... Yes - Fusion was the very 1st thought that came to mind .... I had a look at Fusion's 'tools' list, and did some googling for a 'Fusion method' to achieve this, but didn't get anywhere. The Boris 'glint' settings allow you to select the 'threshold point' (or level) at where the 'glint highlights' are to appear. The number of 'glint counts' (star branches) can be selected, and you can scale the 'size', plus alter the 'width' of the branches. Probably best to 'explain' with pictures ....
Actually - to get the result above, I found I needed to 'isolate' the highlights first. I did that in Fusion with the following 'wiring' lol , - my 1st Fusion project ! (see pic below). I then imported this alpha png sequence (it's a moving camera) into Vegas Movie Studio as another 'layer' directly 'above' it's original, (but 'under' the avatar track of course). It was this layer I applied the glint to. - Seemed to give a sharper, more defined result, - because using glint on the original layer of these lights, gave in a 'blurry' and less defined look. Plus it added unwanted glint to the 'body' (casing) of the lights, so looked 'unnatural'....Edit: So apart from the 'how to' of producing a glint effect, something else has occurred to me..... If you create a scene with both: ●1. 'glint' (for a 'star burst' look) and, ●2. 'De-focus' (for a 'dof Bokeh' look).... then which should come first in your 'order' of FX? #A Do you apply a glint and then de-focus? #B Do you de-focus first and then apply the glint? So which way around would it occur in the 'real world'?
6 Years Ago by
sonic7
illusionLAB
illusionLAB
Visits: 4.8K
Great to see you're "having a go" with Fusion - your idea to hone in on the brightness with a luma keyer is proof you 'get it' more than you may think! The "glint" effect in Fusion is called "hilight". It doesn't offer as many features (in the one plugin) as Boris does, but has the necessary "threshold" and "point count" parameters. Remember, easy way to find nodes is to hold down "ctrl+spacebar" to open search. Also, you pointed out a problem that all "threshold" based effects have in common - glows or glints appearing on 'bright things' in the scene that you don't want... this is where the power of "masking" comes in - not surprisingly, Fusion's masking is as good as it gets!
sonic7
sonic7
Posts: 1.7K,
Visits: 19.4K
