Reallusion Hub not working
Posted By Kelleytoons 2 Years Ago
Rated 3 stars based on 1 vote.
Distinguished Member (22.0K reputation)Distinguished Member (22.0K reputation)Distinguished Member (22.0K reputation)Distinguished Member (22.0K reputation)Distinguished Member (22.0K reputation)Distinguished Member (22.0K reputation)Distinguished Member (22.0K reputation)Distinguished Member (22.0K reputation)Distinguished Member (22.0K reputation)
Last Active: 27 minutes ago
Posts: 6.9K, Visits: 14.3K
So even after updating the Reallusion Hub won't work for me -- says I'm not connected to the internet (and if anyone WAS connected to the internet, it's me, as my entire house can't run without it).
Had to do the latest patch manually.
Rogue Anime
Rogue Anime
Posts: 546, Visits: 3.3K
Same here - These updates need updates. I can't understand the hail of problems here between ver. 7.1, 7.2, Faceware - NOW the Hub. It would seem there has been some change of leadership @RL in the past year. Showers of things like this usually start @the top with those creating the corporate culture that allows things like this to come down the pipeline to users non-stop. FLUSTER-ATED!    Crying ~V~
       Val RogueAnanda
https://forum.reallusion.com/uploads/images/e82de505-c57a-40b9-8cb0-9f87.png
rollasoc
rollasoc
Veteran Member (869 reputation)Veteran Member (869 reputation)Veteran Member (869 reputation)Veteran Member (869 reputation)Veteran Member (869 reputation)Veteran Member (869 reputation)Veteran Member (869 reputation)Veteran Member (869 reputation)Veteran Member (869 reputation)
Posts: 174, Visits: 2.7K
When I booted up the Hub yesterday, it said there was an update to iClone.
I told it to upgrade.  It downloaded the file, then failed to install saying the Hub needed updating.  I then had to update that and then re-download the iClone update again, since it didn't realise it had alredy done it.
Waste of a lunchtime really.
Home built PC:- i9 9900K 32GB RAM, Zotac 1080TI mini.
Band Music:-  https://thehairthieves.bandcamp.com/
Solo Instrumentals:- https://sineglidermusic.bandcamp.com/
Distinguished Member (58.8K reputation)Distinguished Member (58.8K reputation)Distinguished Member (58.8K reputation)Distinguished Member (58.8K reputation)Distinguished Member (58.8K reputation)Distinguished Member (58.8K reputation)Distinguished Member (58.8K reputation)Distinguished Member (58.8K reputation)Distinguished Member (58.8K reputation)
Last Active: 8 hours ago
Posts: 17.0K, Visits: 25.9K
Kelleytoons (6/5/2018)
Hi KT,
I have checked the Hub and it appears working fine for me. Downloads and updates are working as expected.
Sounds like access to our servers is being blocked on your computer. Are you using a proxy or any kind of VPN software?
I was able to do the download manually, so it's not a problem other than the hub (which, as Val and rollasoc noted, didn't work for them either).
I'm not incredibly worried about it -- it's more a PITA than anything else -- but it's something the devs might want to at least look at.
Postfrosch
Postfrosch
Distinguished Member (28.8K reputation)Distinguished Member (28.8K reputation)Distinguished Member (28.8K reputation)Distinguished Member (28.8K reputation)Distinguished Member (28.8K reputation)Distinguished Member (28.8K reputation)Distinguished Member (28.8K reputation)Distinguished Member (28.8K reputation)Distinguished Member (28.8K reputation)
Last Active: 15 minutes ago
Posts: 6.5K, Visits: 15.4K
Yesterday I got the message that I first had to update the RL HUb.
The update of the hub went smoothly over the stage.
Only then could I update IC 7.2 to 7.22 above the RL hub.
Greets from Germany
Postfrosch
2IDs media:design
2IDs media:design
Veteran Member (727 reputation)Veteran Member (727 reputation)Veteran Member (727 reputation)Veteran Member (727 reputation)Veteran Member (727 reputation)Veteran Member (727 reputation)Veteran Member (727 reputation)Veteran Member (727 reputation)Veteran Member (727 reputation)
Posts: 40, Visits: 624
Hi out there
Reallusion HUB Interface displays in false color.
Please see pic. Error since last Update.
also the error i am not conected with the internet.https://forum.reallusion.com/uploads/images/b002fcd7-e5f0-4929-888a-b24f.png
Terry Miller
Terry Miller
Veteran Member (647 reputation)Veteran Member (647 reputation)Veteran Member (647 reputation)Veteran Member (647 reputation)Veteran Member (647 reputation)Veteran Member (647 reputation)Veteran Member (647 reputation)Veteran Member (647 reputation)Veteran Member (647 reputation)
Last Active: 34 minutes ago
Posts: 51, Visits: 1.1K
Mike,
I have had similar problems. My work version of iClone will not go through the Hub, because we have such strict firewall settings. Since installing the Hub, about 1/2 of the assets I have bought are now telling me that they are simply Trial assets and I need to buy them. This was not a problem until I installed the Hub about 2-3 weeks ago (and I only did it then because it said that I HAD to in order to install v.7.22... and then I had to do the same as you and install it manually anyway); anyway, suddenly, I can't use a large portion of my assets. What is weird is that about half DO work, and I can't figure out the pattern of when they will or won't... it's just a crap shoot. I already know what Reallusion is going to say: that I need to copy them from a computer where they are reading correctly and copy onto my work hard drive... apparently that fixes the issue, but it is a long painful process. I wonder if simply uninstalling the Hub will solve the problem?
Anyway, just wanted you to know that I enjoy your YouTube videos.
Thanks,
Terry
Thanks, Terry -- it's always nice to get feedback (sometimes I feel I'm just doing them for myself.  Nothing particularly wrong with that, but it kind of discourages me from doing them.  So hearing that others like them make me want to do more).
kungphu
kungphu
Last Active: 10 hours ago
Posts: 651, Visits: 5.3K
I had the same exact error last week. I was having so many errors that I can’t recall what I did to connect to it. I believe I went into my browser safe websites and added Reallusion.com and that fixed the problem.
My "NEWEST" LatestSmile  Movie Made With Amaaaazing iClone
