sakurarinani
sakurarinani
Visits: 51
Hello I found some problem and can find solution after google and test and error I have problem when import sketchup into here 3dxchange 7 it became seethrough concrete ever though sketchup one is one box Second wrong texture when importing. here in sketchup 2015 Here file same problem is there any tutorial or solution for this 2 problem? above is building 1 and 2 http://www.mediafire.com/file/bv4d2y7tbcdjs2g/PROJECTPROBLEM.rar/file
6 Years Ago by
sakurarinani
Posts: 5.0K,
Visits: 15.9K
Not sure about wrong texture for No2, but for the opacity problem check the opacity map presence for all materials and delete it if there is any (unless the mesh has to be see-through like a glass).
sakurarinani
sakurarinani
Visits: 51
4u2ges (6/3/2018) Not sure about wrong texture for No2, but for the opacity problem check the opacity map presence for all materials and delete it if there is any (unless the mesh has to be see-through like a glass).
Ohh sorry the crane should be red and have some texture like crane no whitr rectangle forgot to upload the pic.. Okay delete opacity in material tab? will try it thank
raxel_67
raxel_67
Group: Banned Members
Visits: 2.0K
This happens whenever your diffuse texture is a png, it will always create an opacity map, delete them
Posts: 5.7K,
Visits: 26.4K
I took a look at the SU models and, as is so often the case with a lot of SU items, they are not really suited for use in iClone. You should be able to get them in through 3DXchange, but not without a lot of work and adjustments. A large number of the "textures" consist of only SU colour swabs and can not be adjusted in either 3DXchange or iClone. These items need to be replaced with at least jpg files to have any success.
