digtalzombie
digtalzombie
Visits: 145
hi i have monster model how can i move his arm away from his leg so that was its not hitting his leg thanks
Last Active: 3 days ago
Posts: 5.7K,
Visits: 26.4K
If the monster is correctly rigged then adjust the bone rotation using Edit Motion Layer:
Peter Blood
Peter Blood
Posts: 2.3K,
Visits: 9.4K
Gerry's got you covered.. I might say, in addition, that as the arm swings through it's entire motion you may have to do this more than once. I usually try and pick the point where the arm is MOST embedded into the body and adjust it at that point. Seems to cut down on the number of times it needs to be done. Also if you adjust the arm at the very start of the movement, you can many times get away with just one adjustment. Hope that helps as well. pete
http://www.youtube.com/user/peterblood50?feature=mhee
digtalzombie
digtalzombie
Visits: 145
thank you so much
digtalzombie
digtalzombie
Visits: 145
thank you
