Data Juggler
Data Juggler
Posts: 1.7K,
Visits: 5.3K
I have tried Camera Zoom, and that seems to make other objects smaller or bigger, but I would like the blue box to be smaller. Is that a property that can be set? Thanks
sjonesdc
sjonesdc
Posts: 1.6K,
Visits: 9.6K
Data Juggler (4/6/2018) I have tried Camera Zoom, and that seems to make other objects smaller or bigger, but I would like the blue box to be smaller. Is that a property that can be set? Thanks
I think that's the " Preview Window (Working Area) - The characters and props in the scene as well as the export range bounded in the Safe Area can be observed in the Preview Window." (described in the manual). I don't thnk it can be resized.
sjonesdc
STILL LEARNING!!!
Data Juggler
Data Juggler
Posts: 1.7K,
Visits: 5.3K
Ok thanks. There are just times I want to record a smaller area instead of having to resize every prop / character.
sjonesdc
sjonesdc
Posts: 1.6K,
Visits: 9.6K
Data Juggler (4/7/2018) Ok thanks. There are just times I want to record a smaller area instead of having to resize every prop / character.I'm not sure I understand what you're saying!. The camera can be positioned to show different areas of the scene and can be zoomed in. Here is an example: The original scene with camera in default position Closeup of part of the scene with camera moved and zoomed in NOTHING WAS RESIZED. Hope this helps!
sjonesdc
STILL LEARNING!!!
Data Juggler
Data Juggler
Posts: 1.7K,
Visits: 5.3K
I also found another way to do it. If you uncheck Lock Ratio, you can set a specific size. I will be a glad a year from now when I know more about this software.
sjonesdc
sjonesdc
Posts: 1.6K,
Visits: 9.6K
Data Juggler (4/7/2018) I also found another way to do it. If you uncheck Lock Ratio, you can set a specific size.
I'm still not sure what you want to do. The Lock Ratio refers to the Width and Height of the character or the prop NOT THE "BLUE Rectangle". Remember the Blue Rectangle represents what is seen through the camera lens. I would really suggest that you save the original scene first, move the camera to the section of the scene that you want, zoom in, do what you want to do, then save the scene. Think of this as if you are making a video, you don't size and resize the actors and/or props, you manipulate the camera.
sjonesdc
STILL LEARNING!!!
6 Years Ago by
sjonesdc
Ibis Fernandez
Ibis Fernandez
Posts: 1.2K,
Visits: 4.3K
You "resize that rectangle" by adjusting the export aspect ratio sizes. Just click the export option (even if you are not looking to actually export yet), then change the export size . By changing the width and height of the export you would also be resizing that rectangle which is basically a preview of the area that is to be exported.
Ibis Fernandez | (available for hire) ---------------------------------------------------------------------------------------- Professional Animator, Filmmaker | Creator of the highest quality (modular) G2 rigs for cartoon animator and developer of Toon Titan and Puppet Producer Author of Flash Animation and Cartooning: A Creative Guide >>> be sure to check out http://toontitan.com for professional grade assets, templates, and custom tools for Cartoon Animator and more.
Data Juggler
Data Juggler
Posts: 1.7K,
Visits: 5.3K
Yes I figured that out already. Sorry I didn't update this post. I also found this other setting that lets you set the 'border' area width; I can't start CTA until my other issue is fixed, but that helped also.
Ibis Fernandez
Ibis Fernandez
Posts: 1.2K,
Visits: 4.3K
you provably just need to update your .net runtime if using windows. Usually solves most issues like that. (not serial number stuff though)
6 Years Ago by
Ibis Fernandez
Data Juggler
Data Juggler
Posts: 1.7K,
Visits: 5.3K
I have the latest Visual Studio 2017 installed (and the latest release) 15.6. I can't change my development environment (which pays my bills) because they are saying 'Invalid Serial Number'. This has to be a licensing issue. The program starts; if it was a corrupt .NET framework the app most likely wouldn't start. But thank you for replying. If it turns out this is the issue I will have to buy another development machine for animation. I am waiting to hear from them, because it was exactly 15 days that all my programs stopped working since I had installed the trial. I suspect something triggered a 'Trial Expired', even though I did uninstalled the trial before installing the pipeline version I purchase. Corby
6 Years Ago by
Data Juggler
