j.piccirillo (3/22/2018)
I create the First Character and move to frame 90 and create the second character ( the German Shepard). I am pressing F3 to view the timeline. I select Bina (German Shepard then click on Visible and it shows key frame (?) diamond starting at frame diamond at zero. I select the diamond at frame zero and drag it to frame 90. The published video is the result. The German Shaper ad is always visible.You do not (and probably should not) need to move the diamond at frame 1.
Position on the on the frame to change visibility and click on the Visible/Invisible menu item.
That will add the keyframe (diamond) to the timeline at that frame you are positioned on.
You can scrub (move the frame pointer) back and forth along the timeline for each character and verify that the visible/invisible is working.
For the character that turns visible at frame 90, position at frame 1 and make sure the Invisible menu item is shown (closed eye).
If not click so that it is.
Move to frame 90 and click to change visibility to visible (open eye).
Move the frame pointer back and forth to make sure it is working.
For the character that disappears at frame 90, move to frame 90 and click on the visible menu button and th character will disappear.
Also look at Kylelee's post above.
I think that dragging the initial key from frame 1 is messing you up. Just move to frame one and click for invisible, that at frame 90 click for visible.
Jeff
