sharter (3/14/2018)
So - is this a scam? G2 power tools downloads and says it has G2 Body, G2 head composer, scenes and props, and 100 commercial objects but when you launch CT3 nothing it says on the site that should be there is there.
Question: Did you use the install.RLD? If so, after running the install, the box that pops up indicating what was installed and where it was installed.
Also, when you click "Save Log", a text file is create, which has a specific information, and the folder "C:\Users\Public\Documents\Reallusion\Content Install Logs" opens automatically as the location to the document.
1. Check the directories listed in the first and second image to see if the files are there
2. Download the pack again OR
3. If all else fails Contact Customer Support.
Hope this helps!
sjonesdc
STILL LEARNING!!!
