neoco1
neoco1
Visits: 263
Hi. I tried change this character's face but it ended up like this :
What i did is just changing colors and enlarging the face. What should i do to fix this?
GOETZIWOOD STUDIOS
GOETZIWOOD STUDIOS
Posts: 1.2K,
Visits: 7.2K
Have you tried to re-import the same OBJ you just exported, without modifying it and see if the problem already happens ? If so you may be confronted to that same issue: 3DXchange v7.2 Replace Mesh Is Broken
-- guy rabiller | GOETZIWOOD STUDIOS "N.O.E." (Nations Of Earth) Sci-Fi TV Show, Showrunner.
neoco1
neoco1
Visits: 263
Yes i did. It didn't help it. I first import iAvatar file into 3dxChange, and click the "Export Mesh" button (only face)
I edited the face by changing it's proportions (i scale the mouth a little bit) and i painted the face. After that i click on the "Replace Mesh" button on 3dxchange. I export and import again and again but it didn't help.
GOETZIWOOD STUDIOS
GOETZIWOOD STUDIOS
Posts: 1.2K,
Visits: 7.2K
Not sure you understood me. Can you test if re-importing (Replace Mesh) an OBJ you just exported (Export Mesh) is re-imported correctly or not ? (without modifying it)
neoco1
neoco1
Visits: 263
You mean without any change? No, it doesn't cause any problem like that. I exported and directly imported, there is no problem with that. However if you change anything, then it somehow become messed up.
GOETZIWOOD STUDIOS
GOETZIWOOD STUDIOS
Posts: 1.2K,
Visits: 7.2K
Ok so it is not due to 3DXchange. And the OBJ you export from 3DCoat, the one you have modified that you try to re-import in 3DXchange, does it import back correctly in 3DCoat itself ?
neoco1
neoco1
Visits: 263
Yes, i imported and there is no problem with that.
GOETZIWOOD STUDIOS
GOETZIWOOD STUDIOS
Posts: 1.2K,
Visits: 7.2K
Then it may be 3DXchange after all ; ) As I'm confronted to the same kind of issue on a particular Daz3d asset, would you be kind enough to make your 2 OBJ files available somewhere for download ? (Goggle Drive or something..): 1) The OBJ file directly exported (Export Mesh) from 3DXchange as is, without any change. 2) The OBJ file directly exported from 3DCoat containing your modifications. I would be curious to take a look at those.
GOETZIWOOD STUDIOS
GOETZIWOOD STUDIOS
Posts: 1.2K,
Visits: 7.2K
Oh and last question, if you import the OBJ containing the modifications you exported from 3DCoat (you can drag&drop it directly into the 3dXchange viewport) as if this was a new prop you wanted to convert, does it load correctly this time ?
Posts: 9.1K,
Yeah, if you post the OBJ exported from XCHange I'll take a look at it as well (I have 3D Coat).
