How to make a inserted video to play or stop at a certain frame? Please help..
Posted By changkenji Last Year
How to make a inserted video to play or stop at a certain frame?...
changkenji
changkenji
Posted Last Year
New Member (30 reputation)New Member (30 reputation)New Member (30 reputation)New Member (30 reputation)New Member (30 reputation)New Member (30 reputation)New Member (30 reputation)New Member (30 reputation)New Member (30 reputation)
Posts: 7, Visits: 29
Ok, lets say i inserted a video as props into my project. How can I make the video to start playing at a certain frame? Lets say i wanted the video to start playing at frame 100 and stop at frame 200. Can this be done? It's annoying with I hit the playback on my project, and then the video that I inserted already starts playing as well... Please help if you know how. Thanks in advance.
vepop
vepop
Posted Last Year
Last Active: 3 hours ago
Posts: 333, Visits: 2.7K
1. Create a still image of the video eg. the 1st frame of the vid.
2. Also, create another still image out of the last frame of the vid.
3. Bring in the video as a prop in Stage mode. Select the prop and switch to Composer mode.
4. In Sprite Editor, add the additional sprites (still image of the video).
In the Stage mode, you can now switch to video or still image on a specified frame in the Timeline by using the Sprite Editor.
Thanks.
changkenji
changkenji
Posted Last Year
Thanks,.... I will give it a try. Another question. Is there a way to control of the video volume in CTA3? Like adjust the volume down or up, fake in and fake out the volume?
kylelee
kylelee
Posted Last Year
Veteran Member (615 reputation)Veteran Member (615 reputation)Veteran Member (615 reputation)Veteran Member (615 reputation)Veteran Member (615 reputation)Veteran Member (615 reputation)Veteran Member (615 reputation)Veteran Member (615 reputation)Veteran Member (615 reputation)
Last Active: 5 hours ago
Posts: 251, Visits: 2.1K
changkenji (2/27/2018)
You can use the visible key to control timing playback your video props.
Below is my test, you can try it.
https://forum.reallusion.com/uploads/images/8712e217-3764-4f36-8b5a-1db5.png
Reply you another question.
- Is there a way to control of the video volume in CTA3? Like adjust the volume down or up, fake in and fake out the volume?
Currently, CTA3 does not the ability to control the video or music volume.
But you can modify your resource through the external editor to adjust volume before insert to CTA3.
lorne.svarc
lorne.svarc
Posted Last Year
New Member (82 reputation)New Member (82 reputation)New Member (82 reputation)New Member (82 reputation)New Member (82 reputation)New Member (82 reputation)New Member (82 reputation)New Member (82 reputation)New Member (82 reputation)
Posts: 7, Visits: 57
Hi, I've done this- inserted video as prop, then adjusted visibility to appear and play at the correct frame. It work for one play back, then, when I play it again it plays from the beginning of the project (though it only appears where I set it to). Any thoughts on how to fix this? Thanks!
scrowner
scrowner
Posted Last Year
New Member (48 reputation)New Member (48 reputation)New Member (48 reputation)New Member (48 reputation)New Member (48 reputation)New Member (48 reputation)New Member (48 reputation)New Member (48 reputation)New Member (48 reputation)
Posts: 10, Visits: 40
I also would like to see a fix to Video prop play issues. I tried vepop's suggestion with adding sprites. However, switching between the sprites for the video does make the video prop change to that sprite but the video still plays while switched to the sprite. I have tried a number of  timeline tricks with making the start frame longer in time and tried inserting frames, visibility on/off - none seem to be successful - video still plays at the start of the project. I would like to see a pause button - as a minimum - to allow control of a video prop. Currently 3.3.3007.1 version of CTA3 allows not real control over the play of the video prop.
Last Year by scrowner
Posted Last Year
Distinguished Member (45.9K reputation)Distinguished Member (45.9K reputation)Distinguished Member (45.9K reputation)Distinguished Member (45.9K reputation)Distinguished Member (45.9K reputation)Distinguished Member (45.9K reputation)Distinguished Member (45.9K reputation)Distinguished Member (45.9K reputation)Distinguished Member (45.9K reputation)
Posts: 15.2K, Visits: 23.0K
scrowner (8/5/2018)
Hi...
All you should need to do is place an Invisible keyframe @ frame 1 and the a Visible keyframe at the point you want the video to start (say frame 100). Then when you press Play the video will not start playing until frame 100. This works perfectly for me with the Windows version. Are you using Windows or Mac?
scrowner
scrowner
Posted Last Year
I am on a MAC. Visibility of the prop does not work. Video prop still plays - just is invisible. So using your example, at frame 100 making the prop visible will have the video already 100 frames into its play.
Posted Last Year
scrowner (8/6/2018)
Are you adding an Invisible keyframe @ Frame 1. That is very important to stop the video playing from the start.
If you are and the issue continues, please contact Support using the link below. They will be able to advise you further on this issue.
scrowner
scrowner
Posted Last Year
Well, frames 1-99, the video prop is not visible, so, I guess so. However, I may be interpreting what you are saying incorrectly. I can see in the props Visible timeline - there is no bar and at frame 100 a marker appears and a line which I believes indicates the prop is visible is present.  You are using the word "keyframe" which is not clear in my understanding. If you do not mind stepping me through the clicks for your "insertion of an invisible keyframe" I can be sure I am doing as you say.
