Postfrosch
Postfrosch
Posts: 6.9K,
Visits: 18.4K
All avatars that I created with the CC 2.xx with IClone 7 can not be imported into Ct 8.13. (Even Jade and Zane can not be imported into C8.) There comes this error message
Avatars I created with the CC 2 before Iclone 7 and saved as IC 6 / CC 1.5 Avatar and exported. The error was noted in the German forumThe program versions CC, IC 7 and Ct8 are up to date Greets from Germany Postfrosch
Evey Fawkes
Evey Fawkes
Visits: 589
Have the same problem. Did you ever get a solution? It's crazy that your CrazyTalk is useless when used with IC7 or CC2.1 In manual it says that you are supposed to be able to "just drag and drop" your IAvatar/character into CT???
Do ensure you have first updated CrazyTalk 8 to version 8.13. Then try sending the avatar to Character Creator 2 and then export from there in "Character Creator 1.5 & iClone 6.5 format". You can see from the screenshot below that this works well for most iClone 7 characters such as Jade.
6 Years Ago by
