Famekrafts
Famekrafts
Visits: 2.0K
I just bought iclone today with 3d exchange pro and trying to export mixamo character to iclone through 3d exchange. When I am exporting, it is not showing any export settings. Check the images, even after export nothing is visible inside iclone. Whether I use a character or a rig, the motions do not export to iclone 7. Any help will be appreciated. I was watching a tutorial on youtube for older version of iclone where it is very easy to export these animation motions to iclone. here is the link
CTA5, Iclone 7, 3D Exchange Pro, Character Creator 3, Popcornfx plugin, Zbrush, Blender, Vue 2014, Adobe cc suite, Spriter Homebuild Workstation (Pretty old now but still working great) Win 10, Intel i7 950, 24 GB RAM DDR3, Gigabyte x58a-ud7 motherboard, AMD R9 390 sapphire 8GB VRAM. Official Website Reallusion Store
6 Years Ago by
Famekrafts
Famekrafts
Famekrafts
Visits: 2.0K
Ok I have found the solution -We need to convert to non standard first, select maya rig, save the profile and then it exports to iclone flawlessly. The only issue is that I have to do this for 1600 animation motions, which is painful. There should be a batch export import inside 3d exchange.
Visits: 60.6K
There is a batch import. Find the animation section in the right-hand panel. Click the import button. Select your motions. You can multi-select a bunch at once (regular Windows selection tools). They will convert with the character when you characterize. Make sure you are using motions that have the same skeleton as your character.
6 Years Ago by
Famekrafts
Famekrafts
Visits: 2.0K
Rampa (2/23/2018)
There is a batch import. Find the animation section in the right-hand panel. Click the import button. Select your motions. You can multi-select a bunch at once (regular Windows selection tools). They will convert with the character when you characterize. Make sure you are using motions that have the same skeleton as your character. Thanks Rampa this really helps.
PhotoSW
PhotoSW
Visits: 570
Just curious, when you import from Mixamo, does the model shift when you preview after mapping the bones? Every time I export a model in, the center shifts forward. It throws off the ability for the character to walk smoothly. I cannot figure it out and making adjustments is not working for me.
www.photosw.net
No, that has never happened. Again, IIRC (it's been at least a few weeks since I've imported a Mixamo model as I'm phasing that out of my workflow and using Blender to skin instead) when you bring in a Mixamo rigged character XChange automatically senses this and maps it accordingly. The only thing I do is adjust the feet positions using those two checkboxes. If you need me I can check this again, but if that's essentially what you are doing (IOW, it all happens automagically) then I'm not sure what you could be doing wrong.
So you got me thinking (always a dangerous thing) and I went and rigged up a Mixamo character and compared it to the original OBJ very carefully in Blender. Mixamo definitely does some *things* with the mesh, including forcing it into a very strict t-pose, way beyond what might be accepted as a t-pose. The arms are rigidly straight (preternaturally) and the back as well, with no curve to the spine. I suspect this is done for calculation reasons, but it has the effect of slightly distorting the mesh and I could see how someone could have a constructed mesh with a more natural s shaped spine that would be pretty well screwed up by this. It's instructive... and basically follows the old maxim of "you get what you pay for". Mixamo is pretty damn good, but it's also not perfect, not by far. One of the main reasons I went with Blender (and a paid plugin to skin perfectly) was to exactly avoid situations like this. Indeed, as I was messing around I found a mesh that, while otherwise fine, Mixamo did not like (my plugin handled just great). I'm glad I've left Mixamo behind.
Famekrafts
Famekrafts
Visits: 2.0K
Kelleytoons (3/4/2018) So you got me thinking (always a dangerous thing) and I went and rigged up a Mixamo character and compared it to the original OBJ very carefully in Blender.
It's instructive... and basically follows the old maxim of "you get what you pay for". Mixamo is pretty damn good, but it's also not perfect, not by far. One of the main reasons I went with Blender (and a paid plugin to skin perfectly) was to exactly avoid situations like this. Indeed, as I was messing around I found a mesh that, while otherwise fine, Mixamo did not like (my plugin handled just great). I'm glad I've left Mixamo behind.I am having a different problem. When I apply Maximo motions to supported characters in iclone, they all start the animation with tpose instead of idle and that is mess in itself. I use the animation tools to fix that everytime. btw which paid plugin are you using in Blender to skin?
IIRC there used to be an option in Mixamo to download the motion without starting with the t-pose but I might not be remembering properly. I dunno, haven't used it in a long time. The skinning plugin is Voxel Heat Diffuse Skinning: https://blendermarket.com/products/voxel-heat-diffuse-skinningIt is every bit as good as the Maya one, and better than the one Mixamo uses (it skins things Mixamo can't handle, and it does it MUCH faster, taking less than a minute). Of course it doesn't create a skeleton for you (you can use Auto-Rig Pro for that if you don't want to do it yourself and that alone is a pretty nice plugin) but I like the ability to custom tailor a skeleton the way I want it. The guy that wrote it is a genius, and I don't use that word lightly (even on myself anymore :> .
Famekrafts
Famekrafts
Visits: 2.0K
I was using Rigify addon to create the bones but I am finding the skinning is not properly done. Will give your plugins a shot
