Axle_Munshine
Axle_Munshine
Visits: 855
Hello to all...I discover Toon maker 2 and I have a small problem.I do not manage to apply the dress of Urvina.This one is available only in the library : " MATERIAL" and not in the "BODYSUIT-PART". When I apply it from there, the top of the body of my avatar disparait (as in the screen shot) and the dress is not of the same color.Can anybody help me please?
TANKS
Marc ARNAUD https://www.youtube.com/user/Francebiographie http://www.france-biographie.com https://www.facebook.com/groups/279372129242230/
vidi
Posts: 10.8K,
Visits: 40.2K
Material fits only to the dependent mesh . In your case you applied the wrong material to the selected mesh
Axle_Munshine
Axle_Munshine
Visits: 855
Thank you for your answer. I tried everything, but the dress is never set up. I have to make an error somewhere, but I do not find. I have this problem only for this avatar. No tuto how explains to make really!
vidi
Posts: 10.8K,
Visits: 40.2K
I tried everything, but the dress is never set uP
if you want help , make not such vague statement . Nobody can know what you exactly try and not work for you. Material is not mesh, it only the cover and to fit only to the depend mesh
6 Years Ago by
vidi
thebiz.movies
thebiz.movies
Last Active: 53 minutes ago
Posts: 2.0K,
Visits: 41.1K
First apply the chubby_upper_dress from the upper folder of the body part section under Avatar Template. Then go to the materials folder and drag and drop the chubby_upper_dress_urvala onto the dress. Finally select you breast accessory in the scene manager and go to the modify materials tools and select the color modifier. To match the color of the dress I just set the brightness to +17.
Axle_Munshine
Axle_Munshine
Visits: 855
It is exactly what I made, but when I made slide the dress, the top of the body disparait....
6 Years Ago by
Axle_Munshine
sjonesdc
sjonesdc
Posts: 1.6K,
Visits: 9.6K
[quote] Axle_Munshine (2/10/2018)
It is exactly what I made, but when I made slide the dress, the top of the body disparait.... thebiz.movies gave you the directions. Just follow them. If this does not work then go the materials folder located here: C:\Users\Public\Documents\Reallusion\Template\iClone 7 Template\iClone Template\Materials Lib\Upper\Materials Lib\Toon Maker2\Upper\Chubby and drag it on to the character on the stage.
sjonesdc
STILL LEARNING!!!
6 Years Ago by
sjonesdc
thebiz.movies
thebiz.movies
Posts: 2.0K,
Visits: 41.1K
The only way I was able to replicate your results is if you accidentally loaded a texture onto the character skin that screws up the opacity map. Click on the character and then go to the material edit tools. Select RL_Upper in the list and scroll down to the opacity slot to see if theres some thing loaded in there. If so, either delete that slot or adjust the strength to zero.
Axle_Munshine
Axle_Munshine
Visits: 855
It is almost good, there is not more than a small problem of color down from the arms which I do not manage to adjust... If you have an idea for that ... Thank you for your help ,
6 Years Ago by
Axle_Munshine
thebiz.movies
thebiz.movies
Posts: 2.0K,
Visits: 41.1K
Just check the diffuse slot in the materials for the skin (RL_Upper). It should be a single peach color. You've likely got another material in there.
6 Years Ago by
thebiz.movies
