Grace (RL)
Grace (RL)
Visits: 5.0K
PopcornFX Plugin for iClone v1.1 - More Enhancements
In PopcornFX plugin v1.1, there will be several new features added to provide you with better particle control and creation, which will be released by late Q2.Note: the following user interfaces are in production form and will be optimized for the final release.
6 Years Ago by
Grace (RL)
Grace (RL)
Grace (RL)
Visits: 5.0K
1. Custom Physics States
The physics property for PopcornFX content can be toggled for None, One Way, or Two Way interaction, which is already available in the PopcornFX Editor.
6 Years Ago by
Grace (RL)
Grace (RL)
Grace (RL)
Visits: 5.0K
2. Sprite Switch with or without Blend
One can now decide whether or not the blend the sprite animation as they appear and disappear.Note: this option (checkbox) is only available for content that carry PKAT data.
In the following examples, the PopcornFX Library 40 and Super Tools Texture Emitter both carry PKAT data, therefore, the Soft Animation Blending checkbox is available.
6 Years Ago by
Grace (RL)
Grace (RL)
Grace (RL)
Visits: 5.0K
3. Particle 3D Sound The new Sound section in PopcornFX Modify panel can be used to switch out audio files and adjust the volume of every Event and Action sound.3D sound is also supported whereas the volume of the sound source will fade in and out according to its distance from the camera.3D sound will also recognize lateral positioning by emphasizing the right or left side speakers.
6 Years Ago by
Grace (RL)
Grace (RL)
Grace (RL)
Visits: 5.0K
4. Path Emitter The new Path Emitter Sampler for version 7.3 can be used as a guided trajectory for the emitted particles.As the path is edited and updated so will the route for the particles.The path data can also be saved and included with the particle effect -embodied in the (*.iPkfx) format.There are three ways to generate a path:- The (*.pkfx) file can carry its own path data which will also show up in iClone's viewport.
- Object's animation path can be picked, be it prop, accessory, character, point light or spot light.
- iClone's Create Path tool.
6 Years Ago by
Grace (RL)
Grace (RL)
Grace (RL)
Visits: 5.0K
5. Curve Attribute
The new Emitter Curve parameter will mimic Curve Sampler editing in PopcornFX Editor -allowing the user to directly adjust the curve shape inside iClone. This has big implication for ease of use.
- Horizontal axis (distribution range): Color from white to black.
- Vertical axis (intensity value): controls brightness.
- Aforementioned settings are unique to this example.
Note: Curve parameter is only accessible for content with Curve Sampler attribute.
Grace (RL)
Grace (RL)
Visits: 5.0K
6. PopcornFX Material Type Switch Material type switching -an original feature of PopcornFX Editor. The PopcornFX Material Type can now be set, providing more rendering flexibility. There is no longer a need to edit the source (*.pkfx) file in PopcornFX Editor to change this attribute.
6 Years Ago by
Grace (RL)
Rogue Anime
Rogue Anime
Visits: 3.4K
@Grace - Thanks for this - looks like the cork finally *POPPED* on those posts of yours we were trying to open over the weekend! ~V~
Val RogueAnanda
mtakerkart
mtakerkart
Posts: 3.1K,
Visits: 28.2K
YES!!!! Thank you a lot GRACE !!
Posts: 5.7K,
Visits: 26.4K
Amazing set of additions and improvements to look forward to.
