Warped Reality VFX
Warped Reality VFX
Visits: 8.1K
Hello hj Hi Kevin the texture are not missed, it does not be shown. This does not change with new version for me. After looking at your example here is what is happening, I am using velocity and time to create this part of the dark energy effect, When the effect is scaled to large this happens, because the scaling is non-uniform only the width is scaled that is how the ribbon works, what appears to be billboards is the stretching of the texture due to a lack of velocity to fix this,I've added new attributes to tailor the effect even more this should resolve your issue plus create more graphic possibility be sure to experiment with the different setting to create even more variations of the effect.
Updated to v2.02 fixed missing texture in dark energy only showing billboard when scaled up added (DarkEnergyTextureType (0-3) allows choosing between different texture at runtime.Added (DarkEnergySpawnAmount , DarkEnergyUpAxisXYZ , DarkEnergyAccelXYZ , DarkEnergyVelocity) Here is a small tutorial with your setting corrected.
Best Regards Kevin L.
Warped Reality VFX.
6 Years Ago by
Kevin L
Warped Reality VFX
Warped Reality VFX
Visits: 8.1K
Hello mtakerkart May in your next update you could implement Gravity feature for the Sparks. for now they go in the Y direction. I will add no problem.
Warped Reality VFX.
mtakerkart
mtakerkart
Last Active: 27 minutes ago
Posts: 3.1K,
Visits: 28.2K
+1 +1 +1 +1
Warped Reality VFX
Warped Reality VFX
Visits: 8.1K
Hi guys here is the lates update GraumagKLv02.0.3 Changes. Updated to v2.0.3 fixed missing texture in dark energy only showing billboard when scaled up added (DarkEnergyTextureType (0-3) allows choosing between different texture at runtime.Added (DarkEnergySpawnAmount, DarkEnergyUpAxisXYZ, DarkEnergyAccelXYZ, DarkEnergyVelocity, SparksGravityXYZ, SparksAccelXYZ ) Fixed,DarkEnergy and EnergyWeb emitter offset issue whwn moving the emitter from location 0,0,0 in iClone.
Warped Reality VFX.
Warped Reality VFX
Warped Reality VFX
Visits: 8.1K
Hi guys.I hope you all are having a great day. Here is a quick wip, update adding a few more attributes, before releasing. Best regards Kevin L
Warped Reality VFX.
6 Years Ago by
Kevin L
mtakerkart
mtakerkart
Posts: 3.1K,
Visits: 28.2K
YES!!!! GO KEVIN ! GO !
Galfridus
Galfridus
Visits: 2.2K
A belated thank you Kevin for the excellent freebies you have provided. Very much appreciated by this user. Geoff.
Jonathan (RL)
Jonathan (RL)
Visits: 256
jasonjbrown (1/29/2018)
I can't get a lot of the particle effects to work properly. The "water wake" effect does not rotate.... I cannot get it to follow a boat properly because it can't stay flat (horizontal) and rotate around corners. The "fur" effect does not appear on the sampled mesh, it appears in a different location than the mesh and cannot be accurately positioned. I also cannot get most of the emitters to rotate properly when their appearance is set to "horizontal". Any help is appreciated! Jason The texture image of current distortion emitter cannot be rotated. This issue was reported as a known bug, and we are working on fixing now. The orientation of Gizmo will be taken into consideration when the align mode is Horizontal.
Warped Reality VFX
Warped Reality VFX
Visits: 8.1K
Hi guys here is the static shield, I hope you guys enjoy it Static_ShieldKLv1.0.rar Static Shield
Warped Reality VFX.
Postfrosch
Postfrosch
Posts: 6.9K,
Visits: 18.4K
Thanks for this FX Greets from Germany Postfrosch
6 Years Ago by
Postfrosch
