Hi, guys I just wanted to respond to some question.
If you're willing to convert the Static-shield in Iclone format with some setting.... Let's say rotation, scale, translation, changing texture, etc... mtakerkart yes I will take look at the static shield and make one for the community. I will also make the plasma ball. I see that jlittle has released his plasma effect also and thank you jlittle for the effect, is this converted for iClone7,
Hello Hj
can you also share the pkfx files, so that i can see the steps to do it ?
I hope this answer will at least give you insight since I don't know your programming skill level. All but the most simple effects are comprised of multiple effects.
Every part of the effect has to be changed to work properly in iclone7, every change I make is through code, for every part of the effect.
As far as adding attributes, most of the effects that come with the editor have very few, if any attributes.So when I add my attributes, it is simply me adding what I think I would want in the effect and to have the most customization for that effect I am working on. I do not expose attributes that already exist, I'm creating them as i go.
So I hope you understand I can not release my code at this time, but if I can help with programming in other ways i'll be glad to.
Hi jasonjbrown.
It looks great, Kevin L..... how did you do it?
The effect was achieved by adjusting the physics settings and other attributes.
Boat wake test
Warped Reality VFX.
