Eyes no more mapped
Posted By slavoisard 6 Years Ago
slavoisard
slavoisard
Posts: 58, Visits: 699
Hi !
I used to convert characters from Daz several time and never had any issue. Now I'm finally working on a real project... I now have my genesis 3 characters that have problems with the eye. Everything seems right in the process, I'm using the latest Genesis 3 Male Duf Key on my Genesis 3 Male, but when in 3DXchange, all the Head, Jaw, Viseme, Muscle morphs are working, but not the eye. And when going on the Expression Editor, I get a message saying the Right Eye, Left Eye and Jaw have not been mapped. Any idea what I'm missing ?
I'm using 4.10.0.123 Pro Edition (64 bits) and 3DXchange 7.2.1220.1 Pipeline edition.https://forum.reallusion.com/uploads/images/ed068bcb-4108-446b-a8ce-c337.jpg
6 Years Ago by slavoisard
ckalan1
ckalan1
Posts: 276, Visits: 10.5K
I am having the same issue. I submitted a ticket to technical support. Their 1st response was for me to watch the tutorial about importing genesis etc. Of course, I have done that many times.
I am waiting to hear back from them after my second report to them about the eye mapping problem. I think some line of code got left out or corrupted in 3dxchange. I will let you know if they fix it.
In the meantime, you can manually map the eyes.
Check this out https://www.reallusion.com/iclone/help/3dxchange5/pipeline/04_Modify_Page/Character_Section/Mapping_Facial_Bones.htm
slavoisard
slavoisard
Many thanks for your answer. Yes, I discovered in the 3DXchange forum that I wasn't alone with this problem. So I will learn how to manually map my characters until there's an update Smile
Posts: 8.1K, Visits: 60.6K
Glad you found that. From your support message, I though you were only having trouble with the Expression Editor. It seems there may be an issue with actual bone assignment.
I'll run some tests with Genesis 8 and 3DX7.2.
I just tested a G8 with a freshly downloaded Genesis Extension, and am seeing this issue as well. It would be good to add it as a bug to the Feedback Tracker.
https://www.reallusion.com/feedbacktracker/
Snarp Farkle
Snarp Farkle
Posts: 770, Visits: 3.6K
I've tried this with the G3 and G8 characters and the only way I can recreate this is to have the "Animations" checkbox unchecked.  I've used both "Genesis8_Male_iCloneFaceKey" and the "Genesis3_Male_iCloneFaceKey" and get the same results. Also, as I'm sure you've noticed, the eyes and lower jaw are not automatically set by the .duf file and you must set them manually in 3DXchange as well as manually setting the eyes and jaw settings in the "Expression Editor".
https://forum.reallusion.com/uploads/images/5f0da580-69b4-47cf-922a-c993.png
Setting the Jaw and Eyes in the Expression Editor will not work if you don't set them correctly in the "Face Bone Mapping" section first, they'll just be greyed out and not adjustable.
https://forum.reallusion.com/uploads/images/84c4a145-3740-43fd-8450-0672.png
Results with "Animation" checkbox unchecked.
https://forum.reallusion.com/uploads/images/d4ed706e-802e-491f-9c42-a9ed.png
Results with "Animation" checkbox checked.
https://forum.reallusion.com/uploads/images/15b3ecc2-0730-499f-a9d0-70c1.png
Here is what I use for export settings in DAZ3D 4.10.
https://forum.reallusion.com/uploads/images/e3a5c594-13fa-4dcf-a666-2ff6.png
There's also a "Reallusion" folder that came with the iCloneFaceKeys that need to be placed in "My DAZ 3D Library\data" as found in the "How to use Genesis8 duf file.txt" text file in both the Genesis8_Male and Genesis8_Female folders found in the "DAZ Genesis Extension" folder.
I don't know if this did anything to help or not but I put them in there!
https://forum.reallusion.com/uploads/images/7afd0f02-96b5-42c1-b593-9185.png
Hope this helps. Smile
6 Years Ago by Snarp Farkle
I dug an old video about setting facial bones. Juicy part is at 3:45.
ckalan1
ckalan1
Great news!
I just got this email:
Dear Craig,
Thank you for contacting Reallusion.
It is being looked into. The Feedback Tracker entry shows "assigned". Expect a fix in a point update. Smile
https://www.reallusion.com/FeedBackTracker/Issue/Eyes-no-longer-get-mapped-automatically
Please feel free to let us know if you have any further questions.
Best Regards
Technical Support
Reallusion Inc.
ckalan1 (1/11/2018)
Great news!
Dear Craig,
Best Regards
Technical Support
Reallusion Inc.
Sorry, I don't when though. Blush
TonyDPrime
TonyDPrime
Distinguished Member (12.7K reputation)Distinguished Member (12.7K reputation)Distinguished Member (12.7K reputation)Distinguished Member (12.7K reputation)Distinguished Member (12.7K reputation)Distinguished Member (12.7K reputation)Distinguished Member (12.7K reputation)Distinguished Member (12.7K reputation)Distinguished Member (12.7K reputation)
Posts: 3.4K, Visits: 12.4K
Thanks everyone for detailing your findings here and for initiating contact with RL.
I too have now experienced the issue, SO IT'S A BIG DEAL NOW.
We can pile Genesis eyes on top of an invisible SpeedTree that glows with Bloom Ring Artifacts, jumps when you use directional puppet more than 2x, and crashes after you mod the bones 5 or 6 times.
I call this syndrome-
"Genesisspeedtreeinvisiusbloomartifactusdirectuspuppetationalbonecrashitus".
