ramuse1970
ramuse1970
Visits: 157
Why do G3 characters have only 2 angles to work with?
kylelee
kylelee
Visits: 4.2K
Yes, you can refer this post. Link: https://forum.reallusion.com/FindPost327075.aspxG3 characters only have two angles, but you can use Horizontal Flip to modify your character.
ramuse1970
ramuse1970
Visits: 157
OK, I'll ask again! Why do G3 characters have only 2 angles to work with?
jlittle
jlittle
Last Active: 10 seconds ago
Posts: 1.9K,
Visits: 17.1K
G3 characters only have one angle. What you are probably looking at are the provided characters in a F (Front) and S (Side) angle. Each of those "angles" is a different character. You can use the horizontal flip on say the S (Side) character to get it to face either left or right. A Front and Side angle are the most used angles so only those angles were provided. For other angles you would need to create the angle you desire by drawing the character at that angle. G2 characters have 8 angles but the characters are harder to create. Jeff
6 Years Ago by
jlittle
vepop
Posts: 1.0K,
Visits: 9.9K
ramuse1970 G3 can have many angles and as many as you like. But you need to create them. The same procedure as for G2 character. G3 character is easier to work with and the result is better (as to my knowledge).
YouTube Tutorials Here
6 Years Ago by
vepop
Ibis Fernandez
Ibis Fernandez
Posts: 1.2K,
Visits: 4.3K
G3 characters are composed of just 1 angle. For every new angle, you have to make a new character. This is good for times when you need a specific angle that a G2 character doesn't provide.
Ibis Fernandez | (available for hire) ---------------------------------------------------------------------------------------- Professional Animator, Filmmaker | Creator of the highest quality (modular) G2 rigs for cartoon animator and developer of Toon Titan and Puppet Producer Author of Flash Animation and Cartooning: A Creative Guide >>> be sure to check out http://toontitan.com for professional grade assets, templates, and custom tools for Cartoon Animator and more.
lesdodds
lesdodds
Visits: 2.6K
ramuse1970
ramuse1970
Visits: 157
So, in other words, G3s are harder to make, but easier to work with inside of CTA? I guess that makes sense!
jlittle
jlittle
Posts: 1.9K,
Visits: 17.1K
G3 characters are easier to make than G2 characters. What do you find hard about making G3 characters? You create the characters parts on different layers using any drawing/photo program that export PSD files. Jeff
ramuse1970
ramuse1970
Visits: 157
I knew someone would take that comment out of context! I simply meant that more work goes into it because each character/angle has to be created as a separate character file, not that it was difficult.
