CrazyTalks Animator 3 Eye Glasses Animation Tutorial
Posted By tech_49 2 Years Ago
tech_49
tech_49
Junior Member (186 reputation)Junior Member (186 reputation)Junior Member (186 reputation)Junior Member (186 reputation)Junior Member (186 reputation)Junior Member (186 reputation)Junior Member (186 reputation)Junior Member (186 reputation)Junior Member (186 reputation)
Posts: 1, Visits: 3
Hi,
Is there any tutorial on how to animate the eyeglasses with the face in crazytalk animator 3?
Please help.
jlittle
jlittle
Last Active: 3 hours ago
Posts: 1.5K, Visits: 12.1K
You can animate them as you would any prop.
How do you want to animate them?
Jeff
kylelee
kylelee
Veteran Member (937 reputation)Veteran Member (937 reputation)Veteran Member (937 reputation)Veteran Member (937 reputation)Veteran Member (937 reputation)Veteran Member (937 reputation)Veteran Member (937 reputation)Veteran Member (937 reputation)Veteran Member (937 reputation)
Posts: 271, Visits: 2.7K
What kind of animation do you want?
If you just want to eyeglasses animate with a face, you just add eyeglasses as an accessory and using Face Puppet to animate your face animation.
If you would like to deform eyeglasses, you can use Prop Key Editor to rotate or transform or Deform eyeglasses.
vepop
vepop
Posts: 443, Visits: 3.8K
Same problem experienced by me before.  When the face moves, the glasses stay put. It does not look natural.
The only solution I guess can work is to adjust it ourselves frame by frame.
vepop
vepop
jlittle
jlittle
Did you attach the glasses to the head?
When you first add a prop to a character the default attach point is a hand.
Jeff
vepop
vepop
Yes Jeff.  The result is still unsatisfactory.
The same goes with the eyebrows.  Btw, I'm talking about attaching things to the morphed head.
Thks.
kylelee
kylelee
You can tell us your issue, I could give you some suggestion.
