Space 3D
Space 3D
Visits: 1.6K
Dear RL and iConer Please help about rendering 3D stereoscopy side by side.
I have rendered with iclone 7 export 3D stereoscopy side by side. Results rendering if viewed with standard 2D player good results, as we render. But if, we see with the video player 3D format results sceene to be fat. The ratio between images is not as fine as viewed with 3D glasses. Data rendering:
- WMV format - 2048 x 1700 HD - Sample rendering 3 x 3 - High Quality Shadow - Side by Side - Convergence Distance 750
Please help us for make better result.
rgreenidge
rgreenidge
Visits: 1.7K
Space 3D, a few years ago I wanted to see how a iClone project looked on my 3D monitors in 3D. I can't remember if I used side by side, or above and under or if one is better than the other and I had the same problem as you after I burned it to a Blu~Ray disc. What I had to do was to change the Pixel Aspect ratio in the render window in the output screen size box. I think I halved it to 50, or doubled it to 200, then everything was the right size, that's all you have to do, good luck. Try it first with only a small section of your project to be sure of which way to go.
Home built; ASRock X570 Pro 4, AMD Ryzen 9-5950X CPU, AMD RADEON RX6900XT, 16GB video card, 131GB of RAM.
Space 3D
Space 3D
Visits: 1.6K
Thanks friends. I will try your methode .
