esemgee
esemgee
Visits: 469
Now not sure of the sequence of events but updated iClone7 to 7.1 then Windows practically forced its upgrade. All Reallusion products are on drive D as C is a 250GB SSD. Since both upgrades happened pretty much at the same time I am uncertain if there were problems before OS change. Now I have no link from Content Manager to anything - just an .ink. My previous desktop shortcuts say that x -which related to iClone 6 - can't be found, it should be in C:, it also asked if the program was mine! (I moved said file from D to C and it now works but this is NOT what I want!). Unless there is a simple way round this, do I need to reinstall everything? From 6 on or is iClone 7 now reasonably independent? Usual annoying, frustrating, time wasting chaos after a Microsoft upgrade! Thanks in advance for any advice - tips - solutions...
7 Years Ago by
garry.smout
Posts: 5.7K,
Visits: 26.4K
All iClone versions are independent of each other, with the exception of some files stored in the "Shared Templates" folder. If you have iClone 6 working OK then try and uninstall iClone 7 - while connected to the internet - and then do a reinstall. The reinstall should read the path to the existing Shared Templates folder and everything should work.
esemgee
esemgee
Visits: 469
Thanks. It seems I don't have iClone 6 working either. See image. The 'custom' folder asked for is in drive D, move it to C and it will work - but I don't want any files in C, only have 100GB left there!! Somehow the path has been rewritten. I noticed that the downloader is now pointing to C but can't reinstall it as version I have is older and can't find where the newer version is to delete it!
esemgee
esemgee
Visits: 469
I could find no logical way of re-setting the path so uninstalled and then reinstalled iClone7 then the 7.1 update. Everything now seems to be linked correctly. Fingers crossed! It would be nice to know if there is a quick way to reset the path as I can see this being a regular event with Windows update!!!
Posts: 15.6K,
Visits: 30.3K
garry.smout (11/19/2017) I could find no logical way of re-setting the path so uninstalled and then reinstalled iClone7 then the 7.1 update. Everything now seems to be linked correctly. Fingers crossed! It would be nice to know if there is a quick way to reset the path as I can see this being a regular event with Windows update!!! Your approach is surely the safest. There is an alternative method that involves editing the registry as discussed here: https://forum.reallusion.com/220315/Relocate-document-and-contents-for-Iclone. It's a hassle though, as it involves making quite some changes. That a Windows update would cause those changes is a scary thought...
esemgee
esemgee
Visits: 469
The Windows upgrade also messed with other shortcuts to other programs and doubled up the shortcuts, some with icons but others without. It really didn't like the apps being on D:
gcshep
gcshep
Last Active: 6 Years Ago
Visits: 3.0K
Hi Garry I have had the same problem and my programs are all on my C drive so I not sure that is the your problem i.e. different drive because I had the same issue also with iClone 7 and Allegorithmic - Painter and then to add insult to injury I had a blue screen crash after installing Curve Editor had the following error Stop Code: DPC _Watchdog_Violation which completely corrupted my whole system and had to do a complete re-install and all this after a Microsoft Windows Update.I did try cleaning but it didn't cure the problems and advise the best thing to do is complete re-instal hence this reply is from my mobile.
esemgee
esemgee
Visits: 469
Well, sorry to hear about your misfortunes but also oddly glad as it means I am not going mad!!! Something usually goes amiss after a Windows update but this is the first time it has changed paths and meant a re-install of software. Have yet to check Character Creator or Crazy Talk fully - they open but have not tried to access anything/item to add to main avatar - so I might still have fun and games ahead of me. The irony is the new update is meant to make linking PC to iPhone dead easy, or something, yet it can't link to stuff already linked! Windoze indeed!
esemgee
esemgee
Visits: 469
I almost forgot: update also removed Quicktime. Apple (also not on my Christmas card list) had decided not to update massive security issues for Quicktime windows and has basically told everyone to junk it. Fine, but my old versions of After Efffects and Premiere rely heavily on it, so to have Microsoft make decisions on removing software from my PC for me is a bit rum. My antivirus is up to anything that Quicktime can let in!!! (I hope!) Quicktime for Windows can still be found on Apple which makes a mockery of its standpoint.
gcshep
gcshep
Visits: 3.0K
It's a disgrace the way these companies treat Joe public if the shoe was on the other foot there would be lawsuits coming at you from all directions
