henrik_71
henrik_71
Last Active: 3 Weeks Ago
Visits: 128
Hi Here is the image with WM. https://www.dropbox.com/s/3skij77h5g4ibaw/skin-weight.jpg?dl=0YEs I select body and dress and choose copied skin weight H
vidi
Posts: 10.8K,
Visits: 40.2K
Influence association Setting to name ?
henrik_71
henrik_71
Visits: 128
Hi Yes all is set. see image: https://www.dropbox.com/s/p8t2jn15m46ji7c/copy-skin.jpg?dl=0The dress is following the leg a little bit, but not very much. H
7 Years Ago by
henrik_71
vidi
Posts: 10.8K,
Visits: 40.2K
It should follow More.because the copy Wight functiin works very well Maybe you make a screencast oft your work workflow
henrik_71
henrik_71
Visits: 128
I Think I found the error. I imported the dress as FBX, and Not OBJ, and looks much better. Now its moving along with the legs. Thx. a lot. I now adjust things so they look ok. and export, but I do not have the game exporter plugin. Can I just export the Dress as FBX? I did try this, and tried to import it into CC, but get and error, https://www.dropbox.com/s/hlxlhm608xvdi5q/error-import-CC.jpg?dl=0I use the fox key from the fox I exported from CC. One thing to mention is when I import the character/FBX into Maya I get this error: There are 3 issues. https://www.dropbox.com/s/yazfywl5vb58nyj/maya-error.jpg?dl=0
vidi
Posts: 10.8K,
Visits: 40.2K
obj or fbx is the same in this case , therefore that is not the fix
your error window indicate, that something wrong in your workflow Hip should never show up in this window and also it is missing the CC Base Components eye and teeth and the dress .
Can it be you have copy the weights from Cloth to the body ? That would maybe explain why your dress not follow the Legs
henrik_71
henrik_71
Visits: 128
I chose the body and then the dress, and then copy the skin W. So right now its working, when I split the legs.
But there should not be the error when I import the FBX into Maya.?
I have tried to import other characters from CC, and all of them have warnings and errors, when I import them into Maya. I use Maya LT 2016
When u export from Maya. Do you export only the dress or also the body? It looks like you export all.
vidi
Posts: 10.8K,
Visits: 40.2K
yes I export all. The Maya Warning can ignored
henrik_71
henrik_71
Visits: 128
OK, So I loaded the game exporter plugin in Maya. and that seem to be missing. I then chose all in the outliner and export selected. There seem to be something wrong with the dress: Error in CC https://www.dropbox.com/s/eutp7phkqyl57ge/mesh-error.jpg?dl=0H
henrik_71
henrik_71
Visits: 128
So I just made the UV mesh in Maya on the dress, and now when I export all, Maya crash all the time when I export.
H
